Low wing pusher configuration?
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by BBerson, Nov 20, 2016.
  1. Nov 27, 2016 #81
    8,887
    5,737
    Always liked the concept.
    Good link, thanks.
  2. Nov 27, 2016 #82
    11,419
    2,095
    BJC likes this.
  3. Nov 27, 2016 #83
    6,351
    2,208
    I have always thought of wing position as relative to the fuselage not the engine position. So most airliners are low wing even though the engines are even lower. In light aircraft where the occupants can often be taller than the fuselage, the people become the reference point, hence "shoulder wing," since a fuselage has no shoulders. YMMV!
    Himat and BJC like this.
  4. Nov 27, 2016 #84
    Himat
    Himat
    Himat
    May 5, 2011
    2,752
    632
    Norway
    Most books I have seen only consider the relationship wing – fuselage when differing between low, shoulder, high or parasol wing position. This is when describing monoplanes layout or the position of one of the wings on a biplane. Pylon mounted wing is if mentioned put together with parasol mounted wings although a wing mounted on a pylon below the fuselage is possible. For whatever reason the designer should chose that.
    Gudmundssons book describe most possibilities quite well, both wing and engine placement.
    Swampyankee likes this.
  5. Nov 27, 2016 #85
    11,419
    2,095
    Sure, that's correct. But for a pusher it gets more complex.
    The questions are mostly with prop/wing interference. So the terminology needs to describe where the wing is relative to the prop and the fuselage if it has a fuselage.
    I want my wing completely below the prop to shield it from rocks, water etc. The wing will be mounted to a low 10" tall tail boom. The wing will be just inches from the ground, even if on top of the boom. Hardly seems logical to describe as high wing just because it's on top of boom.
    See post 71. If that wing was moved above tail boom, it would hardly matter.
  6. Nov 28, 2016 #86
    autoreply
    autoreply
    autoreply
    Moderator
    Jul 8, 2009
    10,738
    2,537
    Rotterdam, Netherlands
    Interesting... no mention of the elephant in the room; laminar flow.
    There's a reason the Avanti is 80 kts faster than a 350 with the same engines...
  7. Nov 28, 2016 #87
    11,419
    2,095
    The two seat Seeker pusher is about the same performance as the four seat C-172: http://www.seabirdaviation.com.au/pages/seeker/
    The Avanti has about twice the wing loading of a King Air, sort of a private jet alternative. A King Air can haul more into dirt strips. I don't know if the Avanti has laminar wings. Usually the boots or stainless heaters (or bugs) trip the flow. A small wing is always faster.
    If I use pusher, it will be for utility, not performance.
  8. Nov 28, 2016 #88
    Himat
    Himat
    Himat
    May 5, 2011
    2,752
    632
    Norway
    The drag created by the wing – fuselage intersection is probably first determined by how the wing is placed relative the fuselage. It would then matter if the wing was moved to the top of the boom on the airplane pictured. And said airplane would then probably have the wing –fuselage drag changed from the typical low wing pattern to high wing pattern. At least for the part of drag created at the wing trailing edge.
    [​IMG]
  9. Nov 29, 2016 #89
    11,419
    2,095
    Probably correct. But with a smaller tail boom, at some point a small tail boom is like a wing with no fuselage at all, I think.
    My wing is 9" thick, about the same as the tail boom so it would likely cover the whole tail boom from top to bottom. Guess they might call that a blended wing/body with lowest drag?
  10. Nov 29, 2016 #90
    Swampyankee
    Swampyankee
    Swampyankee
    Dec 25, 2015
    1,389
    355
    Earth USA East Coast
    How would you classify something like the Douglas Dolphin? 1013px-Douglas_RD-4_Dolphin.jpg
  11. Nov 29, 2016 #91
    6,351
    2,208
    Shoulder wing with high-mounted engines?
  12. Nov 29, 2016 #92
    Aviator168
    Aviator168
    Aviator168
    Sep 21, 2012
    2,196
    245
    Brookville, NY. USA
    According to auto, that's a low wing. LoL.
  13. Nov 29, 2016 #93
    11,419
    2,095
    So why did Douglas put the props so high? Did they want the prop blast above the wing for less drag or some other reason?
  14. Nov 29, 2016 #94
    Jay Kempf
    Jay Kempf
    Jay Kempf
    Apr 13, 2009
    3,531
    865
    Warren, VT USA
    To get them out of the spray normally on this sort of design.
  15. Nov 29, 2016 #95
    12,563
    4,586
    For my own purposes, I have always defined high/low/mid(shoulder) wing by whether there is a substantial section of fuselage below or above the wing, or both. I similarly define the engine location in relation to the fuselage, not in relation to the wing (though that can serve as a secondary classification).
    (I suppose that would define most Northrop and Bernoulli planes as just "wing". :gig:)
  16. Nov 29, 2016 #96
    11,419
    2,095
    Looks much higher than a similar Grumman Goose with engines in the wing leading edge. Those pedestals have a bunch of drag, compared with the Grumman.
    I know NACA did tests of best prop/wing location for typical twins and airliners.
    I wonder if NACA tested prop location of the aft part of the wing for pushers?
  17. Nov 29, 2016 #97
    Jay Kempf
    Jay Kempf
    Jay Kempf
    Apr 13, 2009
    3,531
    865
    Warren, VT USA
    Every designer has his own likes and dislikes in design. Every designer has these subjects that they are convinced are the ONLY way you can do something. We are all guilty of these things. If we are talking about different eras of design then the understanding of what works best or better might have changed in time. Having the prop pulling directly on the camber line of the wing certainly makes for a neutral and stable flying airplane. I wonder if the lower wing position was thought of as helping to use ground (or proximity to water in this case) effect to get the hull out of the water, break suction and get it on the step quicker?
  18. Nov 29, 2016 #98
    Himat
    Himat
    Himat
    May 5, 2011
    2,752
    632
    Norway
    Yes, I follow your argumentation there. If the tail boom is no thicker than the wing and not wider than high you are getting closer to something that look like a wing only. The thing to consider is then the interface fuselage/engine pod – wing.
    How you describe your suggested layout made me remember this one.
    (Illustration grabbed from the internet, I am not that good visualizing.)
    With a thinner tail boom, would it match your layout?
  19. Nov 30, 2016 #99
    11,419
    2,095
    Yeah, that's about it. Of course, a full scale will look a bit cruder to fit a pilot.
    Here is another I found from France. Called Exel.
    http://www.alpaero.com/
  20. Dec 9, 2016 #100
    REVAN
    REVAN
    REVAN
    Dec 6, 2016
    178
    58
    Tucson, Arizona USA
    The Terrafugia Transition is a low wing pusher that comes to mind.
    https://www.terrafugia.com/the-transition/
    I think of the Transition as an enlarged modern remake of Lewis Jackson's J-10.
    Also, I think the Learjets and other similar aircraft can be included in this general description (low wing pusher with engine above wing).
