Low wing pusher configuration?
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by BBerson, Nov 20, 2016.
  1. Nov 20, 2016 #1
    12,513
    2,535
    Can anyone provide an example of "low wing pusher" airplane or ultralight? About all I have found is the Taylor Coot Amphibian and Osprey seaplane and a few motorgliders. I searched a book of 700 designs. What else is out there?
    Note: I am only interested in engine/prop above the wing configuration, not the BD-5 types with the prop in the tail.
    Also, does anyone have flight experience with "low wing pusher"?
    p.s. The Coot and Osprey could be called mid wing, I suppose, except that the Coot wing roots actually sits in the water when floating. And the wing is entirely below the prop arc, so I call it low wing. Where most other pushers are called high wing with the wing near the thrust line.
  2. Nov 20, 2016 #2
    12,513
    2,535
    The Aerosport Rail is another example of wing below the engine and prop (engines, in this case). But I was seeking some more refined designs.
  3. Nov 20, 2016 #3
    Super Moderator Staff Member
    Oct 19, 2003
    6,097
    3,396
    Vari Viggen by Burt Rutan.
  4. Nov 20, 2016 #4
    12,513
    2,535
  5. Nov 20, 2016 #5
    12,513
    2,535
    Yep, that's a low wing pusher alright. My design is conventional tail however, so may not apply.
    But if anyone has Vari Viggen flight experience and can comment about the effect of the high thrust line above the wing, if any, I would be interested
  6. Nov 20, 2016 #6
    13,098
    5,018
  7. Nov 20, 2016 #7
    12,513
    2,535
  8. Nov 20, 2016 #8
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,358
    Las Cruces, NM
    Janowski has a few that are more or less low wingers...
    Victor Bravo likes this.
  9. Nov 20, 2016 #9
    CameronB
    CameronB
    CameronB
    Jan 25, 2012
    67
    23
    North Florida, West Tennessee
    Cirrus vk-30?
    bmcj likes this.
  10. Nov 20, 2016 #10
    12,513
    2,535
  11. Nov 20, 2016 #11
    12,513
    2,535
    More conventional?
  12. Nov 20, 2016 #12
    12,513
    2,535
  13. Nov 20, 2016 #13
    6,694
    2,411
    There was a single VW engine variant of the Aerosport Rail.
    Otherwise, I think you'll have more luck searching for twin-boom light aircraft and picking out the low-wing ones from the results. Here is the old Arpin A-1 (two versions) and the modern Vulcan Ion 100:
    You might also look to some very light jets for inspiration. While more of a mid-wing, SIPA S.200 Minijet is a favorite, and it's not hard to imagine the pod mounted a little higher and sweeping up to a prop instead of down to a het exhaust.
  14. Nov 20, 2016 #14
    12,513
    2,535
    Twin boom just won't work for me. I want the single boom under the prop and the wing under the prop to shield from rocks.
    Or if a seaplane version, to keep water out of prop.
  15. Nov 20, 2016 #15
    11,958
    3,430
    Although a shoulder wing, the Lake Amphibians have a high thrust line. Pireps for them should be pretty easy to find. A tractor, the Seawind has essentially the same high thrust, too.
  16. Nov 20, 2016 #16
    12,513
    2,535
    Yeah, the Lake Amphibian is what I was looking at. But move the wing lower and make the tail boom lower so the prop arc can be partly lower than the cockpit, much like the original early prototype called Tadpole:
  17. Nov 20, 2016 #17
    Himat
    Himat
    Himat
    May 5, 2011
    2,848
    659
    Norway
  18. Nov 20, 2016 #18
    Battler Britton
    Battler Britton
    Battler Britton
    Nov 14, 2015
    511
    351
    Montpellier,LFNG (Candillargues)
  19. Nov 20, 2016 #19
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,230
    1,447
    Marion, Ohio
    I know it says J-3, but that looks like a J-2 to me. Hold on a second....
    ....just looked up both of them. There is not much difference, but I see that the J-3 has the engine mounted higher.
    As far as I know, there are no plans available for the J-3, and the J-2 plans are poor quality scanned-in copies, and in Polish only.
    My build, as I have mentioned, is a J-1B but with a T-tail like the J-2.
  20. Nov 20, 2016 #20
    Himat
    Himat
    Himat
    May 5, 2011
    2,848
    659
    Norway
    Only as radio controlled models, like this one:
    Ok this is maybe a shoulder wing airplane if following the definition strictly.
    Anyway, this and all copies/knock offs have one flight characteristic that a full size would have too. Pitch down on application of power, pitch up as power is decreased. How pronounced this vary a lot between how well the design have been done.
    The Multiplex “original” is quite benign, with very little pitch up/down reaction as power input is changed. Some of the knock offs are on the border of vicious pitch changing with power change
