Low wing pusher configuration?
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by BBerson, Nov 20, 2016.
  1. Oct 20, 2018 #121
    plncraze
    plncraze
    plncraze
    May 12, 2006
    1,592
    332
    Imagine this upside down. It sounds like what you were thinking about
  2. Oct 20, 2018 #122
    12,037
    2,347
    I don't think it was mentioned, but yes the low wing offers advantages for undercarriage arrangements.
    The Dehavilland DH53 picked low wing because it allows short wingtip hoops that drag on rough fields. (Instead of wide heavy gear)
  3. Mar 22, 2019 #123
    12,037
    2,347
  4. Mar 22, 2019 #124
    12,037
    2,347
  5. Mar 22, 2019 #125
    Jay Kempf
    Jay Kempf
    Jay Kempf
    Apr 13, 2009
    3,671
    935
    Warren, VT USA
    There are a bunch of compromises that end up in the design of these fairings. First they don't want the spar through the cabin for standing height. Second the pressure vessel is relatively round so you have to something to blend the very low wing into a relatively round fuselage and above the wing that means trying to get sides of the fuselage vertical. This is for drag reduction for fuel economy. The rest in front and behind is shaped for both critical cruise speed at altitude flows and for low speed separation. Tricky stuff. The wing is also drastically swept and odd airfoils are blended at the root plus there is almost always some sort of change in taper and incidence inboard to keep the root from having a turbulent transition. At high speeds these airplanes are being pushed up near the compressibility limit so the shaping is also dealing with warding off Mach issues. And all that in one piece of fiberglass normally. Fortunately these companies have been at this for a while and they get a bunch of both CFD and wind tunnel time. CFD is getting better and faster.
    For GA the speeds are lower other than that still the same task. Staring at these jet fairings tells you a lot about how to approach the design task.
    BBerson and BJC like this.
  6. Mar 22, 2019 #126
    TAProwler
    TAProwler
    TAProwler
    Feb 16, 2012
    9
    NorCAL
    "Does anyone know why or what these enormous wing root fairings are called on modern low wing jets"
    Why - If I remember correctly, I read that the least drag configuration between a wing and an adjoining surface is either a 90 degree angle or a zero degree angle. Basically, they are building that area up with a large "fairing" to get as much of the fuselage to be as close as possible to a 90 degree angle to the wing or flush with it. Less drag, less burn and more speed.
    What - not sure if there is a specific name for them.
  7. Mar 22, 2019 #127
    12,037
    2,347
    I definately see the need for the 90° intersection upper fairing.
    Not sure what the belly fairing extending below the wing does.
  8. Mar 23, 2019 #128
    RockyPilot
    RockyPilot
    RockyPilot
    Aug 31, 2012
    5
    0
    Philippines
    The prescott pusher is one the the sexiest designs ever that meet your requirements. Love this plane.
  9. Mar 23, 2019 #129
    RockyPilot
    RockyPilot
    RockyPilot
    Aug 31, 2012
    5
    0
    Philippines
    prescott pusher
  10. Mar 23, 2019 #130
    TAProwler
    TAProwler
    TAProwler
    Feb 16, 2012
    9
    NorCAL
    Actually, if you look closely at the Citation X, the bottom of the belly fairing is flat, or nearly flat, across the entire bottom. Then, there is a smooth radius curve that squares off the fuselage and brings it to 90 deg to the lower wing skin. There is a small 90 deg joint between the fuselage and the lower wing almost the entire length of the lower wing skin.
    As someone already mentioned, this is also done to provide a way to cover up the wing spar after it has been pushed way down below the fuselage. These builders are trying to provide as much "stand up" cabin space as possible. It keeps from having to step over the wing spar while walking in the cabin. These large belly fairings help to "cover up" the wing spar and direct the slip stream with the least drag.
  11. Mar 23, 2019 #131
    12,037
    2,347
    That's what I meant. Instead of the seemingly ideal, smooth flat bottom, they put a radiused curve pan under the belly. Same on HondaJet.
  12. Mar 24, 2019 #132
    2,866
    1,600
    So a Taylor Coot, then?
    [​IMG]
  13. Mar 24, 2019 #133
    12,037
    2,347
