Thrust vectoring & plank/
Hephaestus
Jun 25, 2014
1,557
YMM
So I was playing around with the facet opal (Opel?) Plank this morning in cad.
An incorrect selection while trying to sketch in a prop ended up giving me a ducted fan.
And I started looking at it...
Looks a bit like the EADS Voltaire. Less the Vtail.
This is the eurofighter typhoon thrust vectoring nozzle.
I've been playing with a similar system on an rc model lately. There's versions on thingiverse and grabcad if you want to play around.
Haven't played with mixing it on the elevator, but mixed on rudder and as a way to increase/reduce outlet diameter - it's got pretty impressive in the small scale so far.
The variable geometry allows some improved efficiency in the ducted/shrouded fan. Adding a similar system over the leading edge would even improve it more...
What's the possibility that the vectored thrust (and to some extent shrouded prop acting as a ring tail) would be adequate yaw control?
Vertical thrust adjustment would help trim, curious if it would help the landing intricacies of landing the plank.
There's been a bit of ducted fan on tails:
https://en.m.wikipedia.org/wiki/Mississippi_State_University_XV-11_Marvel
https://en.m.wikipedia.org/wiki/Mississippi_State_University_XAZ-1_Marvelette
But they all still have the usual control surfaces.
Thoughts?
jedi
Aug 8, 2009
1,995
You would need to work with the jet ski problem. Back off on the throttle and you loose the rudder (water jet diversion) steering. More than one jet ski has run into the dock for that reason.
A large duct would give some rudder/elevator effect but control would be sensitive to throttle position.
litespeed
May 21, 2008
1,557
Sydney
Correct spelling is "FACET OPAL".
Scott Winton loved his gemstones.
Australia is the worlds biggest Opal producer and the facet part comes from cut facets on a gemstone.
Thus Facet Opal.
3,087
I’m not sold on the prop ring as a control surface but it may make an interesting trim surface.
Hephaestus
Jun 25, 2014
1,557
YMM
Isn't there a difference between a ducted fan and a shrouded propeller?
I'm not even going to try to go there. It's a ducted fan ;) which is a form of shrouded propeller.
And it looks really cool when you use that goldschmeid laminar body and a functional size duct behind it...
deskpilot
Jun 30, 2009
1,121
Getting back to the title "vectored Thrust" Some years ago I designed a plane using this system of control.3 quarter front view (Copy).jpg
The duct moved around the fixed prop and directed the trust to where needed. In this image, the side controls are omitted for clarity. The mounting roller were nylon balls.
I also had thought about swiveling the prop as well but gyroscopic issues meant that a co-axial prop assy would be needed and that's a lot of work and weight at the very tail of the airplane.
Hephaestus
Jun 25, 2014
1,557
YMM
My initial thought was pivot the whole motor/fan/duct assembly. Then I realized the engineering involved o_O
But this way you also get the ability to reduce outlet size which helps at higher speeds. Plus the vectoring...
Still trying to think through leading edge slats to expand the intake area for low speeds. With a 4blade ivoprop variable intake and exhaust dimensions... Becomes less of a point design, little more tolerant of speed ranges and altitude changes.
I know my f86 rc (golden hawks livery) won't take off with 20% reduction in exhaust, but you get a significantly higher top speed if you crank it down once you're up to the higher end of it's speed envelope. Stopped doing it because I can't keep track of it.
I'm thinking incorporated into the duct design, CF laminates for the duct itself, simple hinges - might be able to do CF pulltruded rods and ball links... It's actually not a huge amount of weight. Complexity yes, but at least there's no crazy heat to deal with.
Hmmm... Reminds me of Mr. Stull's "Ring Tail."
Yup, kinda what I started thinking as well when I first goofed and drew it. Then I started seeing the possible options that resulted.
Hephaestus
Jun 25, 2014
1,557
YMM
Sockmonkey
Apr 24, 2014
1,754
Flint, Mi, USA
Ah, I know. Make the main duct fixed, and have a little mobile secondary duct behind it that can slide back to create a larger gap for low-speed thrust, and angle for directional control.
Hephaestus
Jun 25, 2014
1,557
YMM
Risk of flutter scares me here... Very low speed maybe not - once it gets higher...
Hephaestus
Jun 25, 2014
1,557
YMM
http://www.mosquitoamerica.com
Current thrust vectoring craft.
The real purpose is to have the thrust line pass through or below the vertical CG. Vectoring in pitch is very limited.
To trim a plank wing - limited is all it really needs... That airfoils stolen from the Genesis 2 rather than the Opal. They used a tiny Hstab for trim on it, on WL well behind CG/CW - should be able to provide some reasonable pitch moment or is my physics really off on this one?
