The use of the spanwise foam boards between the ribs of an Affordaplane ultralight.
lr27
Nov 3, 2007
3,822
Re: The use of the spanwise foam boards between the ribs of an Affordaplane ultralig
Aren't those where the spars should be?
Aerowerx
Dec 1, 2011
5,767
Marion, Ohio
The standard AffordaPlane wing is a "ladder" type. The "spars" are the tubes at the leading and trailing edges.
So, yes, you could say that they just stabilize the foam ribs. Most of the structural strength is in the leading and trailing edge tubes.
As an alternative you can also use bent aluminum tubes for the upper surface of the ribs.
Aerowerx
Dec 1, 2011
5,767
Marion, Ohio
deskpilot
Jun 30, 2009
1,131
Mine are similar to what Aerowerx shows. They are not fixed to the spar tubes but are slipped into pockets in the Dacron skin rather like battens in a sail boats mainsail..
