Raptor Composite Aircraft
Status
Not open for further replies.
Jay Kempf
Curmudgeon in Training (CIT)
Apr 13, 2009
4,369
Warren, VT USA
For a pusher you would need a prop rod that pulled out of the lanyard tunnel upon deployment if anything had the potential to foul or damage the lanyard.
8,812
Just a thought, how many aircraft that have BRS fitted are 'Pushers' ???? surely the prop would sever the risers as it was deployed.
I think they use kevlar risers that are extremely difficult for a prop to cut. Still won't be fun if it gets wrapped around the prop. You would land nose first...
15,348
I think the rocket deploys straight up from the CG. So a tumbling aircraft could foul in a tractor prop also.
Not without risk.
ScaleBirdsScott
Feb 10, 2015
1,357
Uncasville, CT
Those risers being kevlar indeed should help against a prop. Ideally could also have some extra protective wraps and anti-chafing sleeves where the prop might possibly hit. Having seen what those risers are like working at a parachute company, I'd actually not be surprised that in a battle between blade and riser, the riser wins.
Alessandre
May 28, 2020
70
I could say after the beech starship the raptor is a more beaultifull canard that I had seen. Because of the turbos the engine sounds almost a turboprop.
Kyle Boatright
Nov 11, 2012
1,286
Marietta, GA
It’ll be interesting to see if they get much accomplished today. It is IFR/MVFR in the area this morning and I don’t expect to see good VFR today.
Kyle Boatright
Nov 11, 2012
1,286
Marietta, GA
Justin and Elliot are heading home. No flight this week. Apparently, they don’t want to do the test flight out of here (KCNI) because there are no good options if there is a big problem right after takeoff.....
I’ve been saying that all along. Now what does Peter do? Disassemble it and move to Rome? Try and fly it himself?
Yikes.
Rod Schneider
Jan 11, 2013
36
Ball Ground, GA. About 40 miles north of Atlanta
6,000 feet is 1,000 more than Cherokee. The big issue is where to go if there is a major problem right after takeoff. Cherokee is surrounded by lots of trees and little, if any, open ground. The only decent option would be Interstate 575 which runs roughly parallel to the runway, about 3/4 of a mile or so away. It has it's own issues with numerous power lines crossing the roadway. In Rome (KRMG) there is at least a fair amount of flat, cleared land around the airport.
Kyle Boatright
Nov 11, 2012
1,286
Marietta, GA
Rome also has much friendlier over-runs than Cherokee County. You have grass-fence-trees. Not a steep drop-off directly into a forest.
BoKu
Pundit
Aug 15, 2013
2,964
Western US
Rome looks incrementally better, with a longer runway and longer cleared areas off the ends of the runway. It also has several cleared fields near the airport. But it's still not ideal for early test flights, with lots of timber and rough terrain.
I just don't understand why Peter didn't base the Raptor project out of a large airport in flat geography like Mojave or Cal City or Reno Stead. At any of those places he would have had a better area for test flying, and established pools of composites and aero engineering expertise.
cheapracer
Sep 8, 2013
6,408
Australian
As a number of us predicted.
The weight and rotation speed were obviously not suitable for that strip.
I just don't understand why Peter ....
Good summary of the project right there.
Status
