Flying wing as cheap and simple option for basic fun flying.
Grumpy Cynic
7,446
Compare motorcycle wheels built for conventional motorcycles (little side load) versus motorcycles with side cars. Since the sidecar prevents titling/banking, those wheels need to transfer significant side loads.
But only in one direction unless you have a rider aboard, or are willing to be your own monkey and stand in the sidecar - which I have done. :rolleyes:
One of my best memories is riding in the side car with my father flying same when turning away from the car. Try that today............ :eek:
/thread drift
7,984
The electric wheel/motor combos are intriguing, it would be interesting to see a motorglider or ultralight that used those to get up to takeoff speed and then continued on with a modest motor to the prop that would have otherwise required too long a takeoff run.
Hephaestus
Jun 25, 2014
1,917
YMM
One of the newer gliders does already... Has a sustainer + driven wheel. Can't seem to Google up which one. The direct drive does most of the heavy lifting to get speed up, more efficient than propeller.
Edit - there it is, glowfly
3,468
Just waiting for the “21st Century English Electric Wren” thread to be started...
WonderousMountain
Apr 10, 2010
2,140
Clatsop, Or
This procedure would have been easier to prototype IRL no doubt.
First off, I found the Polygonal body looked a good deal better if,
the upper section became the lower shell. That accomplished, it used
taper into a larger section approaching the saddle area. Immediately,
the Tubes showed a tendency toe in, which likely would be disaster,
in the off design point skid it's intended to perform.
Adding a second set intersecting gets at least a buildable structure.
The Taper on the Body adds a few degrees sweep, but it looks good.
I wasn't able to do the verticles yet, with other projects going simultaneously. Decided against the winglets. It's avoided here because there's enough span & competition entry is unplanned.
It will be getting the regular pair, and a plyon engine pedistool.
Speedboat100
Nov 8, 2018
1,800
Europe
Von Richthofens Wheels where a about 10 times wider then those tiny racing bicycle wheels! So the question remains, will those carbon wheels support the side loads of a not so perfect landing?
Von Richtofen was flying a modern combat aircraft ( of its day ) with dual machine guns....not a bush whacker. Certainly if you need power you can make it lighter.
This would be about 1600 grams with a wooden frame on it in 410 mm dia size.
Sockmonkey
Apr 24, 2014
1,974
Flint, Mi, USA
When you think about it, the high acceleration you can get from an electric motor driven wheel could let you get away with not using a prop at all. Use a bit of down elevator to maintain traction like race cars do until you hit max speed and pull up.
erkki67
Feb 18, 2010
2,330
Look at the ground angle even with that long (and fragile) tailskid...you could hide a SMART car in the blind spot. Tricycle gear with the nosewheel as far forward as possible would be my suggestion, probably with slight negative incidence to the wing on the ground to make landing easier as long as the elevons could lift the nose.
Id like to See this taildragger with Sockmonkeys wing or MikeW’s one but with thé Piojo fuselage, this would make sensé for me for several aspects.
one of them is the simplicity of construction, the wing is square, so its easy for an average builder to line up.
due to a narrow fuselage, the space required for building is also eased up and fwd visibility is a non issue.
erkki67
Feb 18, 2010
2,330
I like simple designs, a squarish plank with a similar looking fuselage pleases my eyes.
if the fuselage is integrated like on a few Sockmonkey sketches or hang below a MikeW wing Doesn’t really matter, it must be simple and straight fwd.
i was clearly influenced by Fritz, with his contributions to those matters here, simple lines, and easy to accomplish in a single car garage.
Aesquire
Jul 28, 2014
2,456
Rochester, NY, USA
Using powered wheels to lower takeoff distance doesn't seem a good trade off. That's weight that does zero good in the air, uses power/fuel/battery at the expense of range, extra complexity, and the least bothersome to me, special takeoff techniques that some one not familiar with the intent & details of controls could mess up and run off the runway. Wheel motors in power regen/braking mode all the way down the runway at full throttle? Run out of juice 5 miles down the river valley because the the gear is on full power and you didn't hear the noise over the wind?
Introducing new failure modes and expensive parts.
better to have more power for climb, flight, and run the motor at a lower power setting in cruise to keep it cooler.
Aesquire
Jul 28, 2014
2,456
Rochester, NY, USA
And, yes, I know the Airline guys list electric powered wheels as part of their New Green Wish List of Sales Bullet Points on the slide before Supersonic With No Boom Profit Promise, and right after Regenerative Braking from Windmilling Electric Turbines and We Hope No One Learned Newton's Laws and became a Journalist Anyway.
Hephaestus
Jun 25, 2014
1,917
YMM
Actually you're trading a bit of mechanical weight for a huge battery weight/kwh saving.
Propeller drive is the least efficient. Hub motors are most efficient. Takes way less kwh to do it with a wheel than with a propeller.
Norman
Nov 28, 2003
3,061
Grand Junction, Colorado
You would be adding dead weight to an airplane that already has inadequate power loading. Acceleration on the ground is nice but if the power available is cut in half when you leave the ground that extra motor is just dead weight that will reduce your rate of climb and both ends of your speed range. Offsetting the extra motor weight by throwing some battery cells overboard is a false economy, you still have an overweight under-powered airplane with equipment that could be contributing to flight but isn't so now you can't go as far, and climb-out still sucks. Some flying cars deal with this problem by having one engine drive both systems and de-clutch the wheels while in the air. A roller chain and a couple sprockets would be a lot lighter than an electric motor big enough to provide acceleration better than a propeller.
8,812
The traditional way to shorten takeoff without too much extra weight is with RATO assistance. Model rocketry probably has stuff that would be of use to us.
8,271
All of this engineering-kwon-do, and Rube Goldberg-ing, and electro-complexifi-cation... just to not spend the money on a controllable pitch propeller and one of RV6ejguy's SDS systems for an appropriate IC engine... :).
Riggerrob
Sep 9, 2014
1,712
Canada
I predict that - within a decade - airliners will use electric tugs to help them accelerate to 100 knots on the runway. Then the tug dronedis-connects and drives itself back to the charging station to wait for its next customer.
The chief advantage is shorter take-offs.
A secondary advantage is burning less fossil fuel.
Bill-Higdon
Feb 6, 2011
913
Salem, Oregon, USA
