Windows 10???
Discussion in 'Hangar Flying' started by Aerowerx, Oct 2, 2015.
  1. Oct 3, 2015 #21
    skier
    skier
    skier
    Mar 5, 2008
    1,078
    337
    CT
    This^^
    If I were just using it for internet browsing, minor text editing, and a little programming, I'd do Linux in a heartbeat. Since I use it for photo editing, some gaming, and CAD, I'm stuck with Windows.
  2. Oct 3, 2015 #22
    clanon
    clanon
    clanon
    Jun 6, 2007
    1,101
    217
    It means the SMART system on the HDD is a narc and it's telling W7 that is really tired of working.But it could be running years this way.You could also get to the disk from the bios setup (usually F2 or Delete keys before start of w7) and when inside the HDD settings just DISABLE SMART , you'll have auto ; enable and disable options when you get into HDD settings) Usually in the first tab of the BIOS settings.
  3. Oct 3, 2015 #23
    delta
    delta
    delta
    May 27, 2011
    1,978
    200
    Brookside Utah
    A google search brought up many options for getting rid of their spyware. I would consider something like this if I were to install windows 10. pXc-coding ยป DoNotSpy10
  4. Oct 3, 2015 #24
    13,081
    5,010
    Ghost your hard drive before upgrading. If you don't like the results, then you can restore your old system.
    (Make sure you understand what "ghosting" means before you do this.)
    clanon likes this.
  5. Oct 3, 2015 #25
    Don't do this! 'Hard drive failure imminent.' Is a Windows euphemism for a smart error message that should read something like 'This drive is going to die within 24 hours.' 50% of the time it is already too late to recover your data. (Unless you pay a small fortune to have it stripped down in a clean room environment - even then, they can only get it all back if it's head or bearing damage. If it's the disk surface then recovery is problematic.)
  6. Oct 3, 2015 #26
    Don't know about games but for graphics work GIMP has been better than Photoshop for many years now.
    A few examples for CAD:
    3D - FreeCAD, VariCAD(non-free). Bricscad(non-free).
    2D - Draftsight, LibreCAD, Medusa.
  7. Oct 3, 2015 #27
    And it *is* rather amusing to watch Micro$oft scuttling along 5 or 10 years behind. I'm pretty sure there's some bits still left over from DOS in there somewhere ;^}
    (I use SUSE Tumbleweed so UBUNTU is also a bit dated from my viewpoint.)
  8. Oct 3, 2015 #28
    Super Moderator Staff Member
    Jul 30, 2005
    13,963
    5,576
    Speaking from the point of view of someone doing commercial graphics professionally for the last 25 years, no, it's not. GIMP has some nice features, but the UI is arcane and Photoshop is simply the far better tool when you actually have to make a living off the work.
    I have nothing against Linux, but Adobe doesn't publish for that platform and I make my living using Adobe's tools. Linux isn't an option for me on my workstations. My Linux flavor of choice is Google's implementation of Android, which is perfectly fine for the kind of internet browsing/e-mail/light word-processing being talked about here. Most of the text in my Conceptual Design thread was typed up in Google Docs on my Nexus 7 tablet with a Bluetooth keyboard, for example. It's easier to cart around than a laptop, and I was able to do most of that work sitting in a local restaurant over breakfast or lunch. Was just doing more of that work this morning, as a matter of fact.
    Midniteoyl likes this.
  9. Oct 3, 2015 #29
    Double post - the network glitched just as I sent it - always get problems at the start of the rainy season.
  10. Oct 3, 2015 #30
    Jul 30, 2005
    13,963
    5,576
    Already fixed it. No worries.
  11. Oct 3, 2015 #31
    WonderousMountain
    WonderousMountain
    WonderousMountain
    Apr 10, 2010
    1,853
    193
    Clatsop, Or
  12. Oct 3, 2015 #32
    6,536
    2,459
    Ditto!
    Already downloaded and installed. Looks interesting but I haven't the time today to play much. Dual boot on this XP box is being stubborn ...........
  13. Oct 4, 2015 #33
    PTAirco
    PTAirco
    PTAirco
    Sep 21, 2003
    3,494
    1,010
    Corona CA
    When I got that message, I was still able to run it in safe mode and I had all my data backed up on my second hard drive anyway. I think it was physically worn out, after 6 years or so. I still have it and will simply put my old back-up hard drive into and it will become my workshop computer.
    clanon likes this.
  14. Oct 5, 2015 #34
    Lucrum
    Lucrum
    Lucrum
    Jun 10, 2008
    956
    189
    Canton, GA
    Downloaded & installed Windows 10 last night. Been using it much of today with no issues.
  15. Oct 5, 2015 #35
    JamesG
    JamesG
    JamesG
    Feb 10, 2011
    2,408
    754
    I find it annoying that my Win 7 now has an unrequested "Get Windows 10" icon in my system tray that I have to make go away.
  16. Oct 5, 2015 #36
    clanon
    clanon
    clanon
    Jun 6, 2007
    1,101
    217
  17. Oct 5, 2015 #37
    It's an incompetently programmed, monstrously bloated attempted copy of some gimmicky stuff that UNIX based systems were trying around 2000.
  18. Oct 5, 2015 #38
    6 years is not bad. We normally assume a half life of 5 years - so 50% should still be running after that time. Unfortunately the failure rate line is not linear - new drives tend to either die almost immediately or carry on until either the bearings wear out or the bad sector count exceeds the number of spare sectors provided.
    Above a certain error count, the disk may totally refuse to work even if it is not damaged - this sometimes happens when a laptop overheats - the sensors in the drive detect the heat and register it as a series of errors. Sometimes it is still possible to recover the data at this point by replacing the drive board, but the replacement has to be absolutely identical.
  19. Oct 5, 2015 #39
    clanon
    clanon
    clanon
    Jun 6, 2007
    1,101
    217
    I've found that the new drives (after 2005 and more than 100gb) failing in about a year of intense use...lately.
    But i also find every week some old (a 100GB and under that size) working nice , even being beyond 5 or more years old...:ponder:
    PS: "oh... the good ol days of everlasting stuff"
  20. Oct 5, 2015 #40
    Jul 30, 2005
    13,963
    5,576
    This thread is getting off-topic for itself, and has always been OT for HBA. Let's keep it tight to the OP's original question and not descend into the OS Holy Wars, please.
