The Ranger, an easily built high wing LSA runabout
7,376
MTB airshocks are worth a look if you want light springing and damping. My cost-no-object landing gear would use lengthened ones. Sadly, cost is a problem, so they are unlikely...
erkki67
Feb 18, 2010
1,887
A trailing link gear on the Ranger, hmmmI like that idea too, But I’m going to stay with the initial design.
Fritz, how is the wing going to be built up, do you have a 3D image available?
7,120
How is that any different with any other type of gear? I was actually thinking the opposite, that this could be relatively simple as cantilever steel tube gear just welded in pace when you make the firewall or bulkhead with a tabs welded in to bolt on the trailing link and shock.
Only glitch I see is how to set alignment and make it easily built and indexed/aligned in the home garage.
7,049
The Ranger is all about KISS. No, not Gene Simmons' KISS either. Simple, cheap, low-parts-count monolithic fiberglass landing gear is ideal, with welded tube bungee gear being the second best option if nobody wants to make a glass gear.
GeeZee
Feb 25, 2019
70
Indianapolis, IN
Wow, post 674 about the half VW using Harley cylinders. The guy is even willing to sell kits or partial kits. Hope this design works out! Wish Mr Plumb had gone with Harley cylinders on the O-100.....
For a simple gear for the Ranger, how about going the Sonex route and use titanium bar slipped into a 4130 tube socket?
radfordc
Feb 5, 2008
1,328
Even simpler, use the Airbike design....steel tube leg in steel tube socket. Much cheaper!
GeeZee
Feb 25, 2019
70
Indianapolis, IN
Agreed a little cheaper. 3/4” bar from “titanium joe” isn’t as $$ as you would think. Sonex claimed the titanium had different properties than steel as far as energy absorption/rebound or something to that effect. I never bothered verifying their claims. I’ve got both the single and two place airbike plans. I like the design.
GeeZee
Feb 25, 2019
70
Indianapolis, IN
“Engine wise my dream would be a direct drive two stroke engine with oil and direct fuel injection of about 50hp.
Air cooled and boxer would be perfect.”
erkki67
It sounds like you are describing a McCullough drone engine....(the reworked ones of course and minus the direct FI). There are threads in HBA about it on a Hummel bird.
FritzW
Jan 30, 2011
3,852
Las Cruces, NM
That sounds like it could be light, cheap and fairly simple. ...I'd better fire up the electric drafting machine and see if the sandwich would fit.
I've got some Airbike plans laying around to take inspiration from...
7,376
The difference in hp and weight in the engine options puts the V speeds all over the chart. ...and I'd be a fool to put in writing that Vs wasn't <24kts (and it will be). Vh under 55 kts is probably a given with anything under ~45hp. On a ~40hp'ish airplane that's designed for 6.6G and a Vne under 100 mph it's safe to say that Vc = Vh. Vy depends so much on hp and prop specs that it's impossible to even guess (I don't even know if the engine will have a PSRU yet).
It's an optimized HiMax wing on an airplane that's very similar. It'll fly okay on 35 hp and it'll fly great on 50 hp.
That sounds very 103. i thought you were going LSA. Those speeds mean that a Briggs would really benefit from a redrive. A Luciole DD setup is going to suck that slow. The 810 with as much torque as you can find might sorta work.
radfordc
Feb 5, 2008
1,328
I tested the hell out of my Sonex gear! I ran off a narrow runway into tall weeds and put the plane on its nose....bending one leg about 10 degrees. My buddy worked in the machine shop at a large power plant and helped straighten the leg with a 50 ton press. He said it was scary how much force it took to straighten the leg. That gear leg is still flying hundreds of hours later and hasn't shown any problem.
Dillpickle
May 3, 2014
132
Piny Woods, Tx
Re: landing gear. 18? years ago, we built a single seat homebuilt using the composite leaf springs from I believe a Chevy Astro van. They were $50 each at a wrecking yard. We were able to sand, saw, drill, and shape the composite springs to our liking. According to this article (link following) "...IFC Composites (Haldensleben, Germany), which has been mass-producing glass-reinforced epoxy-based leaf springs since 2005. The company uses a semi-automated prepreg manufacturing system, during which continuous fiber is impregnated with resin. IFC has reportedly supplied more than 1.3 million composite leaf springs for light-duty trucks, including Daimler’s Sprintercargo van. The Sprinter front axle leaf spring manufactured by IFC measures 1400 mm/55 inches long, 75 mm/3 inches wide, 30 mm/1.18 inches thick and weighs 5.5 kg/12.1 lb compared to the 25-kg/55-lb steel front leaf spring it replaces." ONE POINT THREE MILLION! springs out there from this manufacturer alone. When I was doing the research nearly two decades ago, some European Land Rovers and the Astro and Corvette all used some type of composite leaf. Corvette was out because the price of all things Vette is obscene.
The springs we used were strong enough out of the box (van?), but needed to be a shade stiffer. We wrapped them with another two layers of cloth and they ended up working well on a 750 lb airplane. While the sprinter van specs given may be a little heavy, they might be sawed down and tapered. Or there may be a another option out there, as I would guess most Chevy Astros with the Composite MonoLeaf spring have long since been recycled.
reference article: https://www.compositesworld.com/articles/composite-leaf-springs-saving-weight-in-production-suspension-systems
and a quick google shows Volvo using them as well. This article even has a pretty good picture of the application: https://omnexus.specialchem.com/news/industry-news/henkel-volvo-benteler-sgl-composite-leaf-springs-000186237
billyvray
Aug 17, 2005
739
Newnan, GA
what was the type of airplane or what was it similar to?
How was the leaf spring used? Is it cut in half (and tapered, modified) and each piece clamped in the fuselage as and independent leg? Or, was is used as a large single unit ?
Just curious.
"Dillpickle, post: 472658, member: 30739"]Re: landing gear. 18? years ago, we built a single seat homebuilt using the composite leaf springs "
7,049
Mr. Meglinsky, a previous participant in this forum, has offered composite springs that were designed for small aircraft. However, the narrow fuselage of the Ranger makes a one-piece spring more complicated to mount. There would likely have to be a wide "pad" or plate under the fuselage with gussets, and this would not look very attractive.
In terms of using a fiberglass gear, Billy Ray's idea (above) of clamping two springs onto the sides of the fuselage is probably a better idea than my comment above about a monolithic one-piece spring. If the clamp bolts go all the way through the fuselage, at least there would not be any tension loads trying to "peel" the fuselage sides apart.
There is also a good case to be made for the welded bungee type gear on this aircraft. Legal Eagle gear might be nearly perfect as-is, just narrowed enough to fit the Ranger's fuselage. I'm sure Rockiedog can offer some expertise on the durability or off-road-worthiness of the LE gear.
I made up a sketch of a composite gear but I can't figure out how to upload it into a post.... what happened?
