The Ranger, an easily built high wing LSA runabout
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by Victor Bravo, Feb 19, 2019.
  1. Apr 27, 2019 #601
    akwrencher
    akwrencher
    akwrencher
    Oct 16, 2012
    1,116
    402
    Gustavus, AK
    Would it be possible to just run a slightly longer stub exhaust from the top cylinder bent and over to one side? I don't know if that would get it far enough from the pilots fresh air supply or not, but it would be simple......
    My OCD wouldn't let me do that either.....although it might be possible to mount it like a Y.....
    FritzW likes this.
  2. Apr 27, 2019 #602
    Dillpickle
    Dillpickle
    Dillpickle
    May 3, 2014
    70
    28
    Piny Woods, Tx
    [QUOTE="FritzW,
    My OCD won't let me run 2 cyl's down one side and 1 down the other...[/QUOTE]
    I FEEL YOU!!!!!!! I literally chortled. Would splitting the top tube into two tubes and running those down each side work for you visually? A full collector ring would enter PITA world.
    akwrencher likes this.
  3. Apr 27, 2019 #603
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,660
    179
    How to integrate the exhaust on a Verner and Ranger.
  4. Apr 27, 2019 #604
    6,234
    5,046
    Well that just leaves me with a big question mark...
    Dillpickle, Tiger Tim, BJC and 2 others like this.
  5. Apr 27, 2019 #605
    6,448
    2,289
    From a model aircraft engine, but it's an elegant design.
    [​IMG]
  6. Apr 27, 2019 #606
    6,989
    1,931
    Looks like the engine must be mounted Y! Maybe Scott can tell us about any flaws to that idea?
  7. Apr 27, 2019 #607
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,660
    179
    Exactly what we need here.
  8. Apr 28, 2019 #608
    Blackhawk
    Blackhawk
    Blackhawk
    Apr 18, 2008
    119
    20
    AUSTRALIA
  9. Apr 29, 2019 #609
    daveklingler
    daveklingler
    daveklingler
    Jan 23, 2013
    57
    19
    Albuquerque
    A quick google search a while back found a bunch of people offering teflon bearings that were actually designed to be bearings, a few dollars apiece, with lots of engineering numbers including wear time at various continuous loads.
    I concluded that was a pretty good way to go the next time I needed a few. They're more expensive than a stick of PVC or PEX, but not that much more, and I'll only need a few.
  10. Apr 29, 2019 #610
    6,989
    1,931
    I have used plastic Igus bearings. But they are only cheap if you buy a lot in the same size.
  11. Apr 29, 2019 #611
    6,234
    5,046
    I must say I don't like the idea of the Kung Pao Rotax in Post #608. The whole concept pf the Ranger was intended to include an equally fundamental focus on low operating cost without sacrificing high reliability, which is why the industrial V-twin was the first choice.
    The V-twin engines are well known to run very reliably over a long period, slow piston speeds, low internal running stresses, less heat, lower RPM, less noise, etc. etc.
    A $2,000.00 base engine, with a couple of hundred dollars in very simple HBA parts for the belt redrive, seems like the sweet spot to me. Rebuilding a less expensive used V-twin into an aircraft engine (bringing it up to 45-48HP in the process) would save a little more money too.
  12. Apr 29, 2019 #612
    Blackhawk
    Blackhawk
    Blackhawk
    Apr 18, 2008
    119
    20
    AUSTRALIA
  13. Apr 29, 2019 #613
    6,448
    2,289
    I think the Ranger power options are similar to what I was discussing for the Fokker V.40 parasol pastiche in another thread. There is a sweet spot for four-stroke engines in the 35-45 hp range that gives you a range of options at increasing cost from the budget industrial V-twins with redrives to mid-range half VWs and finally the top-of-the-line Verner 3VW radial.
    erkki67 likes this.
  14. Apr 29, 2019 #614
    6,234
    5,046
    I believe it is absolutely correct to say that the mission and intent of the Ranger, from the start, was to be a near-minimalist, very inexpensive, very user-friendly, little off-road dirt bike for a pilot who already has developed the basic flying skills.
    erkki67 likes this.
  15. Apr 30, 2019 #615
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,660
    179
    The ring will do the affair.
    Regarding the aft fuselage structure, is it geodetic from a routed plywood panel, or is it made from glued together sticks?
  16. Apr 30, 2019 #616
    ScaleBirdsScott
    ScaleBirdsScott
    ScaleBirdsScott
    Feb 10, 2015
    1,074
    689
    Uncasville, CT
    Verner has said the Y is not a supported config. Mainly because of the case oil drain being unable to, well, drain. It may well be that, with some modification at the factory or by the user, such a setup is possible, but I can't say if there's an allowance in the material to go adding more drain fittings there. The heads should be fine with it.
  17. May 1, 2019 #617
    rtfm
    rtfm
    rtfm
    Jan 3, 2008
    3,192
    572
    Brisbane, Australia
    Hi erkki,
    From the look of it, they're sticks.
  18. May 1, 2019 #618
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,660
    179
    Fritz, is the aft tail cone structure a routed milled one or stick built up?
  19. May 1, 2019 #619
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,660
    179
    As according to this pic it looks routed?!
  20. May 1, 2019 #620
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,720
    3,341
    Las Cruces, NM
    It's built out of sticks. The picture looks like routed lattice because it was easier to draw.
