This example isn't on an experimental, it is on the EAA's B-17 - Aluminum Overcast, which is grounded for the time being with a wing attach issue. Anyway, at the bottom of the linked page is a sketch of the wing mounting structure that caused the aircraft's grounding. What I found interesting is that there are attach points for the upper and lower spar caps - a very common attach method. But there is also a middle attach point. Doesn't that middle attach point make the entire mounting concept structurally indeterminate - where you can't easily calculate the load path? It just seems really odd to me.
Here's the link: Update on EAA B-17G Aluminum Overcast - Aero Vintage Books
Can someone help me understand the how/why of that middle attach point?
