rod for Gas welding
Discussion in 'Tube and Fabric' started by bcguide, Jul 1, 2014.
  1. Jul 1, 2014 #1
    bcguide
    bcguide
    bcguide
    Nov 18, 2013
    15
    8
    hudson hope
    So I need to do a repair on my wing strut and was wondering what rod to use for welding on it I cannot remember whitch grade of steel it is but it is not 4130
    Thanks
  2. Jul 1, 2014 #2
    dcstrng
    dcstrng
    dcstrng
    Oct 17, 2010
    913
    323
    VA or NoDak
    Like “oil” and “Powerplant” threads, this will probably start a huge debate… nonetheless I use RG45 for acetylene on 4130 – why, it was recommended to me years ago, seems to do all I could ask and I have a large supply of it…
    I am not a professional welder, I’ve never seriously thought about becoming a professional/certified welder -- I do envy the work the pros can do, but I don’t know any professional welders personally, so take this with a grain of salt.
  3. Jul 1, 2014 #3
    JIC
    JIC
    JIC
    Dec 31, 2010
    290
    43
    Middleton, Idaho
    I also use RG45 for welding 4130.
  4. Jul 1, 2014 #4
    13,075
    5,005
    I guess JIC doesn't quite grasp the concept of a debate. ;) :gig:
  5. Jul 1, 2014 #5
    bcguide
    bcguide
    bcguide
    Nov 18, 2013
    15
    8
    hudson hope
    Thanks for the quick responses. I think this strut material is 1020 steel will the rg45 work for that as well
  6. Jul 1, 2014 #6
    dcstrng
    dcstrng
    dcstrng
    Oct 17, 2010
    913
    323
    VA or NoDak
  7. Jul 1, 2014 #7
    JIC
    JIC
    JIC
    Dec 31, 2010
    290
    43
    Middleton, Idaho
    bmcj, I don't debate things I always loose:gig:
    akwrencher and bmcj like this.
  8. Jul 4, 2014 #8
    PTAirco
    PTAirco
    PTAirco
    Sep 21, 2003
    3,490
    1,009
    Corona CA
    I always used commercial grade mild steel rod for 4130. My parts always passed all the lab tests. I talked to a long time A&P the other day who insisted that you need to use 4130 rod. You do not. Unless you can heat treat it afterwards, it leaves a fairly brittle joint. The low carbon mild steel stuff makes for a better joint in most applications.
    Paul Stalenberg and BBerson like this.
  9. Jul 8, 2014 #9
    bcguide
    bcguide
    bcguide
    Nov 18, 2013
    15
    8
    hudson hope
    An update
    The nearest welding supply is 60 miles from me so I did some practice welds with what I had, coat hanger and Er70s2. I took my samples in to the guy who does the annual on my J3 and he liked the coat hanger weld the best,LOL.
    The welding supply shops did not have any RG45 but I was able to order some in for later in the week.
    My A&E gave me some RG60 and some 4130 to try out I don,t like the RG60 it does not seem to flow out very well. The 4130 is strange it almost seems plastic, it welds nice and has a good looking bead
  10. Jul 8, 2014 #10
    10,010
    6,759
  11. Jul 11, 2014 #11
    Super Moderator Staff Member
    Oct 19, 2003
    6,063
    3,349
    I use ER70S6 because TM Tech thinks it is the best for non-heat treated joints in 4130 airplane tubing. It is mild steel rod with more deoxidizers, and it works very nicely for me on both mild steel and 4130. YMMV.
    wltrmtty likes this.
