Billski- removing the down switch is an interesting idea. It would leave the pilot with one more thing to do during landing, though, wouldn't it? He'd have to watch the pressure gauge in addition to the other things he has to do during that busy time.
But I'm thinking once the gear locking arm was overcenter the gear would be locked anyway, wouldn't they?
From Elliot Seguin's video, he described a limit switch in the circuit that powers the hydraulic pump. When the gear swings to the down position, it cuts off power to the pump in the down direction.
The common scheme in hydraulically driven landing gear systems is that the system powers the gear all the way to down and locked, and then keeps it there. When all the cylinders hit the end of the travel, the pressure climbs high enough for the high pressure switch on the pump to open and shut off the pump. There is also a low pressure switch on the pump that energizes the pump to keep pressure above some minimum amount too, and this system is set up to do this anytime the gear switch is in the down position. No added effort for the pilot. Select gear down, the electric motor spins in hydraulic pump to drive the gear down, sequencer valves make sure the doors are open before the gear actuator is pressurized, then the gear is driven down and overcenter to lock down. Most of us have three gear legs to get down, so the system should make pressure in the down direction until all three go over center and lock. Once everything is in the down and locked position, then the switches/valves keep it all pressurized in the down and locked direction. No big deal, and pretty robust. Not as robust as down and welded, but pretty darned good. Many thousands of airplanes running some variant of this, and malfunctions are rare. There might be up locks, down locks, gear doors closed again after the gear swings, etc, but these do not change the system that swings the gear and then holds pressure in the down and locked direction.
After take-off, move gear switch to up position, the pump runs and sends oil in the opposite direction (either by valving or pump running in the opposite direction, the down locks (if applied) are released, doors opened (if they were closed), the sequencer valves apply pressure to the up side of the various cylinders, and the gear swings up into the wells. Once there the sequencer valve closes the doors, everything hits its stops, the pressure comes up, and the high pressure switch cuts power to the pump until pressure comes down enough to make the low pressure switch, pump comes on again... Some systems throw up locks, others just hold it shut with pressure.
Last step is to move the switch to the down position with the pump not able to run (for whatever reason). The switch is connected to not only the electro-hydraulic pump, but releases all system pressure and pulls any uplocks. Then some sort of springs and/or gravity pulls the gear down and hopefully to locked position. There are airplanes that do not swing down by gravity, but would have to be manually pumped down, or even blown down by stored pressurized gas.
Your airplane appears to have had a limit switch set up to cut power to the pump as the gear hits the down and locked position. It is nice to know the gear is locked - those three little green lights are there for a reason - but if the switch is made just a skosh early, the pump shuts off and will not be powered again in the down direction. If the gear leg linkage went over center, it might stay put until you have it back in the barn. But if it is not quite over-center and vibration or landing loads try to fold the gear, there is nothing maintaining pressure to stop it. Most systems have the down and locked switch, but it only turns on the green light for that wheel, not disconnecting the pump. Then there is the whole issue of the switch is one more thing that can lead to the gear not working, etc. It sounds like someone thought they were the smartest person in the room, but ultimately made a choice that left Elliot with no way to get the gear down and locked...
The pilot never switches pumps on and off, only moves the switch, the hydraulics move the gear, and the high and low pressure switches on the pump keep the system pressurized no matter which way the little wheel shaped switch is moved.
Please be very skeptical of every system in this airplane. You have already seen an electrical system that shut off your engine for no good reason and a gear system that leaves your gear unlocked. I would be reviewing every system and its pieces from a couple perspectives:
- What is the usual way this is done on other reliable airplanes? When you find stuff done differently, get other folks involved;
- Look at everything and say "what failure modes can happen to this part and what effect will that have on my safety?"
Both paths should lead from you to some other smart folks who know how these things are normally done and can give advice on how to do it right on your bird. I would not go changing your system based upon some free commentary given on the internet by a retired guy who used to engineer automatic transmissions. Nope go back to some engineer who is temporarily working for you and see how they think it should be set up. Then go through everything. Personally, I recommend the AeroElectric Connection and then review that electrical system. Once you are used to asking the what if this fails this way questions and figuring out if your electrics make sense or not, you can apply that thinking to the landing gear, but I suppose you could do it the other way around too.
I do believe that a system using best practices running the structures you already have may be your single best path. Lots of folks are safely running electrically dependent engines and retractable landing gear. You should be making sure yours is set up so it runs safely too.
