Minimum = 45
Maximum = 90
Thanks. And this is where statistical analysis comes into play (something that no one ever wants to consider, because it makes stuff look as dangerous as it actually is, rather than just sweeping failures under the rug and hand waving about successes).
Everyone is always talking about the things that DIDN'T fail. But a success is almost meaningless from the standpoint of failure analysis - if a system has a 1% failure rate in 100 hours, then 99 out of 100 of the people you talk to are going to tell you that their system works fine - no issues, in the 100 hours they've flown their plane. But a 1% failure rate is miserable, particularly when you're talking about a catastrophic failure (and I use the word "catastrophic" here in the FMEA/SSA sense, not in the hyperbolic sense). So the only response that's meaningful out of those 100 is the one failure. And here we are.
Now, if you make some assumptions about how to calculate the upper bounds on failures, we can see (using the binomial method) that with one failure in 100 units, the upper bound on failure rate, with a 95% confidence level, is 4.65%. That means that in 95% of the populations of 100 units, no more than 4.65% of the units in that population will fail. If there is one failure in 50 units, the upper bound is 9.1%.
These, to be extremely blunt, are freaking miserable failure rates, and no one in their right mind should get into a plane that has an upper bound of 4.65%, much less 9.1%, on a catastrophic failure probability.
No matter how much one likes the visuals of the design.
Now, since you were discussing total electrical failures, IF one can redesign the electrical system so that it's not susceptible to the type of failure that occurred, then the failure RATE will decrease substantially and the plane can be made safe to fly.
Jim and I have not been able to find a schematic from Titan for a "stock" T-51 electrical system. Whether the system in his plane is "per Titan's specs" or was made up by the builder, we don't know. But it's clearly brain damaged either way, as everyone has stated. And we're going to address that with a modified system based on AEC's Z-19 or Z-101 schematic, which I suggested to Jim after my visit, and which (not coincidentally) Billski also recommends. Once that's done, we may or may not address more of the landing gear mechanical design, depending upon Jim's wishes.
