Jungster 1 & 2 aircraft
Dominic Eller
May 16, 2019
73
Good stuff! That’s a lot of work to get that plug carved! Keep the pictures coming.
Can’t wait to hear the test flight report.
M Clarke
Nov 8, 2020
20
California
My jungster had a nice panel with some basic instruments but I had a sheet of carbon fiber laying around so I decided to make it fancy… Im Replacing most of my instruments with an iPad, which will display information wirelessly transmitted from a levil aviation BOM. This will eliminate the pitot tube/static port and all associated plumbing currently in the aircraft. I am keeping my tachometer and oil pressure/temperature gauges.
B633A63F-044B-4686-9A1A-AEDD92C86959.jpeg34E0EC10-90A2-4A2C-84AC-78104443AA8C.jpegCD885166-CBE3-498C-ACE1-D09D1404E643.jpeg65CF524D-3E21-4BDB-B098-6549568CECFE.jpeg
M Clarke
Nov 8, 2020
20
California
My panel was pretty basic and the only instruments the iPad is replacing are a compass, altimeter, airspeed, and variometer, however the iPad is displaying much more than that so I will compare it to an equivalent steam gauge panel. I’ve left out a tachometer, and oil press/temp gauges since it doesn’t replace them. Here are the cost breakdowns. All prices for steam gauges are from aircraft spruce.
Ipad $720
Ipad mount $300
BOM $1500
Total $2520
Compass $190
Altimeter $650
Variometer $270
Airspeed $775
AoA $389
G meter $180
Turn and slip $526
Artificial horizon $765
Directional Gyro $1500
Suction gauge $194
Static port $19
Heated pitot tube $300
Vacuum pump $260
Vacuum regulator $300
Vacuum filter $40
Hose fittings $10
Nylon hose $25
Total $6393
Keep in mind some of those prices are for certified gauges and some experimental, I was really just clicking on the first results I saw, but that should give you a ballpark price...
edwisch
Aug 11, 2020
74
How fast does the BOM have to go to start giving usable readings? Etc.
9,390
SSSC
Compass-- $25 from ebay.
Altimeter-- $40 from a IFR Cherokee Arrow that wouldn't pass IFR certification by a small amount.
Airspeed-- Helo airspeed given to me by neighbor IA
Slip indicator -- Given to me by neighbor
Oil pressure --- NAPA auto parts store ?
Oil Temp--- NAPA auto parts store ?
Tachometer-- Tinytach-- $17 , ebay.
Ipad with Avare-- $147. Amazon
Ipad mount --- little scrap aluminum
Seat belt and shoulder harness-- Given to me by neighbor FBO owner.
What I call basic.
Dominic Eller
May 16, 2019
73
That will be a cool panel, and likely lighter weight than the old one.
How much does the BOM weigh?
I’m looking at the Karnadia 3 in 1 AS,VS, Alti the Digi engine monitor and a digital G meter. All up with a carbon panel I’m picking under 2lbs 👍
M Clarke
Nov 8, 2020
20
California
Pops,
I was comparing brand new instruments to be fair... You can absolutely make a panel very cheaply. You should be flying airplanes like these by looking outside anyways so it doesn’t really matter what’s on the panel. I just thought it would be neat to try out a new gadget.
9,390
You are correct, basic instruments for a very basic airplane. Looking outside . At the least, I'll take a compass and an oil pressure gauge.
M Clarke
Nov 8, 2020
20
California
I hadn’t heard of the karnadia instruments before, looks like they make some good stuff! Engine monitor will be nice to have too.
It’s looking like the weight change on my panel will be negligible. The BOM weighs 1 pound. I won’t have a battery or starter either. Should be interesting to see what the empty weight is.
14,961
There was a thread years ago on homebuilt instrument requirements. I believe only one is required and it had nothing to do with altitude or direction.
9,390
Oil pressure and splurge with a compass. I can do without a fuel quantity gauge. I always dip stick the fuel tanks and fly by time by the fuel burn.
So I don't need fuel gauges. All they have to do is read empty when the tanks are empty.
