Ul engines
rotax618
Oct 31, 2005
825
Evans Head Australia
What about a direct drive Suzuki G10, hand proped, battery ignition, Bing carb, auto flexplate. Probably lighter than 1/2 VW, no complex building or counterweights.
rotax618
Oct 31, 2005
825
The G10 engine can be leaned over up to 80deg towards the exhaust side to raise the thrust line in tractor situations. A small turbo can be fitted to increase the low end torque, a muffler is not required when a turbo is fitted so there would be no net weight gain.
13,092
I think Jeron had one on the test stand. With radiator and coolant not light enough for an ultralight, as I recall.
The Generac 993 is lighter by far.
12,812
Many planes are designed around the engine, so if you want to use something else, it might cut into the design if you don't think it out. Not as plug and play for numerous reasons. A good ole Rotax s hard to beat if in good shape but the 1/2 VW would be my pick.
lr27
Nov 3, 2007
3,822
There are 4 stroke paramotor engines which are pretty light.
What sort of ultralight are we talking about? I'm assuming a part 103 legal ultralight. Even then, ultralights with long wings, clean lines and light pilots will need less power than others. I'm thinking one of the latter might possibly be flown with a vertical shaft, 500 cc Briggs that's got a weird redrive or has been converted to horizontal. But, of course, that's a project.
This is already done, but it's a bit on the large side, IMHO:
http://www.soloflightltd.com/SOLO ENGINE..html
This is sort of interesting:
http://www.renntechkarting.com/products_xf40.html
Verner Motor has 3 cylinder radials that don't need redrives, though they're a bit heavy.
This one's interesting too:
http://www.vernermotor.com/old/index474c.html?sec=41
However, I think it's out of production.
You might try poking around for airboat or hovercraft engine conversions.
rotax618
Oct 31, 2005
825
The definition of an Ultralight is different in different countries, if you strip the Suzuki down to the bare engine, add a side draft 32mm Bing and a simple 3 into one exhaust the actual weight is about the same as a 582 Rotax, in direct drive configuration it would be only about 40ish HP but would be easily light enough for our Ultralight Category in OZ.
dougwanderson
Jul 21, 2014
142
Lakeville, MN USA
the solo 35 and 40 seem a bit optimistic on there numbers.?.?
snowmobile 4 strokes.
Kevin Armstrong [video]https://m.youtube.com/watch?v=8WG990wAD0A[/video]
