No one can explain WHY planes fly...
PiperCruisin
Jan 17, 2017
146
Idaho
Interesting, but I'm just going to assume a "spherical friction-less chicken" and move on.
Aerowerx
Dec 1, 2011
5,355
Marion, Ohio
Heisenberg: You can't know the position and momentum of a particle, both at the same time.
If you know where it is, you don't know where it is going or how fast.
If you know which direction it is going and how fast, you don't know where it is "NOW".
13,249
So if you have two people observing, one position and one momentum, does that mean that together they know everything or nothing? :confused:
jedi
Aug 8, 2009
1,932
Excuse me please. I can not ignore a good question or challenging puzzle but I need more information.
I will assume the two people have similar characteristics to simplify the number of solutions. That given, are the two Republicans or Democrats?
Aerowerx
Dec 1, 2011
5,355
Marion, Ohio
One of each, so there is never a chance of agreement. Heisenberg's uncertainty principle is still valid!:p
jedi
Aug 8, 2009
1,932
Ok. I am wishing I had never posted “anything”, then I could say that until now I have posted “nothing”. I guess that proves that you can never go from “something” to “nothing”.
Now I have a good come back for when the wife says “without me you would be nothing”.
dog
Dec 29, 2019
225
Assuming zero friction, a perfect vacuum, and zero degrees Kelvin...
Airplanes cannot fly.
Welllll, your stipulated conditions do give rise to superfluidic states of matter,condusive to levitation
jedi
Aug 8, 2009
1,932
For the same reason anything flies: It pushes air downward to move upward.
It would be more accurate to say that it pushes down on the air. Whether the air actually moves and the direction and velocity of motion depends on too many variables to actually predict or accurately measure as has been previously pointed out in great detail.
jedi
Aug 8, 2009
1,932
Make that "it accelerates the air to produce a force" and we are in agreement.
Nope. If the air has enough resistance you (or the wing) can push and the air will not move nor accelerate. Air holds airplanes "up" all the time without being accelerated. True, a Pits Pilot might not know this but lets make this a contest and see who can explain what I am thinking as an example.
Anybody want to bite!
Hint: Think outside the biplane and it's multiple "wings".
PiperCruisin
Jan 17, 2017
146
Idaho
Not sure where you are going with this, but think of acceleration as a vector. Or think of the acceleration of a ball on a string being spun in circles. Now imagine that as an air particle as it curves up to go over the top of the airfoil, then curves down to follow the curvature, then reverses direction again as part of the pressure recovery.
