Minicoupe
pwood66889
Feb 10, 2007
1,858
Sopchoppy, Florida, USA
Thanks, Tim. Guess I muffed something. Or memory faded faster than usual...
And the thirteen and a quarter inches is for the half-width, as AeroWerx noted: "IIRC, the PDF I had showed half the firewall pattern. "
14,488
Without getting plans out and if it’s like the T2, it requires some fab and welding. You might be able to cheat and use a Zenith part for some of it. It was designed in the day where a prefabbed part was only engine, wheels and brakes. The T2 is very simple. I had one I dissected as a teen. It wasn’t worth saving but it was interesting. The Minicoupe is bigger with a 4 ft more span and fuselage, and weighs 150 lb more. It’s not a pure cross over.
Aerowerx
Dec 1, 2011
5,722
Marion, Ohio
Can you please elaborate whats wrong with nosewheel assembly please?
I don't know. It just seemed like there are too many welded joints, and the whole thing seems rather "clunky". There are other designs that are a lot better.
Remember this is for the Teenie Two, not the Minicoupe.
14,488
It’s just not prefab. Not really any more work than any other design, you can’t just buy it. The plane I owned had the steering welded straight which along with a direct drive 440 two stroke which was probably the demise of it. I don’t know what they did to the Windwaggon or Hummel fuselage, but I would not tail dragger a T2 without those updates. That probably goes for the Minicoupe.
pwood66889
Feb 10, 2007
1,858
Per my plan set, the MiniCoupe nose gear is simpler than the Teenie 2 one from Aerowrex. That drawing does provide the detail for the nose wheel fork that seems to be missing from my plans.
What my plans do show is a straight pipe with plates welded on at an angle. Those plates provide the pivot points. A steering rod runs from the bottom of the rudder bar to a link on the arm. I can try for pictures if of interest.
And if interest fades, I'll take the carcus for MyMonoCoupe - a single-place Ercoupe with linked nose gear and rudder.
JaTro
Apr 12, 2021
8
Still waiting for Mr. Dixon reply with banking details. I wonder, are there any other alloy plans for single seat low wing scratch build available? I know and like work of Leeon Davis. But, some other plans?
Riggerrob
Sep 9, 2014
1,877
Canada
MacDonald S-22 is a similar all-metal, low-wing, VW engine, etc. The prototype was a tail-dragger. With its single fin, it has a more "classic" look. With a few cosmetic changes to the spinner, cowling and turtledeck, it could become a stand-off-scale Messerschmitt 109.
5,993
Many people build their Sonex expressly as a (spacious) single seater. The plans are available from Sonex, along with parts if you want them.
Thatcher CX4 is a plans built design, too.
Jerry Lytle
Jan 3, 2014
421
Newport, Oregon
"What my plans do show is a straight pipe with plates welded on at an angle. "
Pray tell what size pipe? and is it gas or water?
