LMA Build in the UK, to SSDR spec.
flywheel1935
Nov 1, 2018
494
Downham Market, Norfolk, Great Britain.
Hi Percy, had an email from Cliff, Freds' son, a week or so back. To be honest he didn't really give me much info, apart from "possibly" getting more involved with the LMA
website ???? but despite several other "interested parties" ??? posting emails, nobody has heard back from him ,yet !!! I am going to sail my own voyage on my build, as there is some
poor design elements that simply need to be addressed, then redesign the airframe ,so that UK sourced materials can be used. Cliff did say that after a while, I guess early 90,s
that the Alloy tube used 1/2" x 3/4" x 0.035 6061-T6, was no longer available, so left it to other LMA builders to use what they could find ????? . Nick Onn was 25th at the WAC in France
yesterday, with one more routine to go. I'll speak to him soon, Alan.
pwood66889
Feb 10, 2007
1,860
Sopchoppy, Florida, USA
There is an LM-5-XW available for $17,500 in Texas... :) Comes with an O-200 that has "been run monthly."
Am seeing if there could be some manuals available from him. A couple quid for a point-pdf would be worth it for me.
What would be the URL on the "LMA web site?"
As to "poor design elements," Fred just scaled up the Real Thing.
Percy
flywheel1935
Nov 1, 2018
494
Hi Percy, heres the LMA website> https://groups.yahoo.com/neo/groups/LMA_builders/info
Regarding 'poor design' !!!! key components such as the landing gear and wing lift strut points, are extrusions that have to be mounted on top of rivet heads
that hold the Airframe gussets in place, I,ll post photos. I'm guessing that you and Fred may well have been friends ???? but I've yet to come across
decent aeronautic solutions to the kit build, looks like each and every model was a modification of the previous model , hence the confusing array of builds available.
He would have done a huge favour to the the 'Kit Plane Industry' to develop and fine tune 2 or 3 models, and get them correct. Even the hardware in my kit is wrong, as grip lengths and nominal lengths
have been mixed up, so the recommended bolts,(as per the build manual) are either to long or to short, by the threaded portion, !!!
I may come across as being critical of the LMA kits, but unless you'veIMG_1904.JPG built one, especially the metal airframe then I feel justified in my thoughts.
PTAirco
Sep 20, 2003
3,610
Corona CA
Looking at the right fuselage side, it appears the is no real triangulation around the door frame. I know you need a door to get the flesh servo inside but I would add some tubes and gussets to make that area take its share of the load. Right now you have an unbraced polygon there. And yes, I'm sure it works but it wouldn't take much.
flywheel1935
Nov 1, 2018
494
Hi PTAirco, yes, these are the design issues that keep appearing !!!!, one of the first times I realised the design was flawed was checking the loading point for the undercarriage.
Logic says it should use the same load path as the wing pickup points, ??? but the rear pickup turned out to be mid span of the lower longeron, no loads should be mid-tube, but at a nodal point.
I will be beefing up the door opening, and added a 'hardpoint' at the rear landing gear pickup.
pwood66889
Feb 10, 2007
1,860
Thanks for that LMA group link. May have to squint around.
Did contact one person with an LMA for sale. He had no books, and shared a hand-drawn part. Very thin gruel.
I would not say Fred was a "friend." Just that I am a "Social Butterfly" and am keen on airplanes. I visited him one time because he was close. Then my job transferred me where a person was that had offered him a place on his air field in New Mexico. We did correspond at length.
I believe Mr. Fred was trying many things to gain commercial viability. Perfecting a design was probably not his style. I appreciate his innovation with the square aluminum frame, but do grant your construction points.
flywheel1935
Nov 1, 2018
494
Hi Percy, think your starting to see my point !!!! As Fred used 3/4" x 1/2" tube, at every gusset, ( bearing in mind this is a 'Bonded' Airfame ) 33% of bond area is lost on the 1/2" side !!!
We used 3/4 x 3/4 for our rear longerons, so bond area is equal at each join. No stress measurements were supplied to the UK/Eu importer, so that killed sales this side of the pond.
Its also not a "Quick Build" there are close to 250 gussets in the build, from design to manufacture + cleaning, deburring, fitting, drilling, bonding then riveting ! Its close to 1 hour of gusset time, for each one, theres already 250 hours ish. Anyway as Ive got plenty of spare time,and a free airstrip and Hangar I'll just plod on with the build. !!!
pwood66889
Feb 10, 2007
1,860
Stress measurements do not seem to have been Fred's style. And any measure was so prep dependent that I doubt if 2 could be close hand running.
His innovation was going with square tubes and bonded construction in the first place. Others, like the LePelican, used round and bolted. Not my idea of good joins between members. I can send you pictures of what LePel had to do to make the joints any where solid.
And yes, the gussets had to be one-off for each join - perhaps 2 if the other side matched well enough.
There seem to have been a few LM airframes come up on sales sites I get. If one was close enough, and cheap enough... Percy
flywheel1935
Nov 1, 2018
494
Just come across another poor design element !!! as the wing roots are different lengths, due to the cockpit being tapered, ie; 36"
wide at the front spar, and 33" wide at the rear spar, the brackets that hold the "root spars" are now at an angle of over 90deg, so theres a tapered
gap at a major stress point......( Percy, if you see a cheap LMA, run a mile). We are going to redesign over the winter a new "parallel " fuselage, and use the current one
only for trial fitting of controls, etc.
flywheel1935
Nov 1, 2018
494
Going to redesign above bracket, and incorporate a "Wing Fold System", as per 'Kitfox' style aircraft. Mocked up system and seems to work fine, just need to machine
hinge from alloy billet, then look at "parallel" fuselage, "Skunk Works Nofolk" !!!
erkki67
Feb 18, 2010
2,434
From where did you got your 3/4” tubing from and which quality?
rgds Erkki
flywheel1935
Nov 1, 2018
494
Hi erki67, As you can imagine the 'Homebuilt Aircraft' scene in the UK is not very big. I had to source via the UK Spruce and Speciality importer,
the tube is 0.049 thou wall, 6061 T6, 3/4 x 3/4 supplied from KAISER ALUMINIUM, Chandler AZ, and UPS only ship in 8ft lengths, which is also a real pain.
Hence MK2 will use UK sourced material, hope thats of help. Alan.
flywheel1935
Nov 1, 2018
494
Working on the wings at the moment,( too cold to bond ) as we are only building as a Single Seater, were loosing a couple of feet off the wingspan + squaring off the tips, need to not have too low a wing loading ! also going for smaller ailerons but with a bit more movement, by a few degrees. IMG_1969.JPG IMG_1970.JPG
