Moderator note:
This topic originates from the tiltwing/tiltrotor discussion in this thread:
http://www.homebuiltairplanes.com/f...87-roadable-aircraft-design-6.html#post125288
I completely agree with the need for retaining a low wing loading for emergency in private aircraft.
But the tiltwing/tiltrotor configuration is a dead end for private use, however, in my analysis. Three reasons:
1) overly complex... always a problem
2) complex transition from hover to cruise
2) static lift props are hardly optimal for cruise
The solution is fixed and optimized lift fans for static lift and another engine/prop for normal cruise.
The DO-31 got it right with multiple lift fans.
Moving to the highly-loaded wing areas, optimal for cruise isn't a wise thing to do I think, neither for a roadable, nor for a tiltwing/tiltrotor. Impact energy for something like a 40 kts stall speed is low enough to make even the most horrific crashes survivable, pretty similar to cars.
