Easy-to-build steerable nosewheel?
Grumpy Cynic
7,724
How about suggestions for an easy-to-build, bolt-together, free-castering nosewheel without welding?
The no welding limitation does make simple/easy a bit harder ;).
How about a couple of aluminum "U" channels cut to length and facing each other with a bolt through both for the pivot - bolt/rivet some aluminum arms on one for the wheel mount - and a couple of "U" bolts on the other clamping the assembly to a fiberglass/spring steel rod leg?
8,305
Those Wipline nosewheels do look slick, though I thought free-castering nosewheels were a no-no for floatplanes/amphibians. I guess they just get up enough speed going up the ramp not to worry about it. Anybody have a clear, closeup pic or drawing of a Wipline nosewheel?
FritzW
Jan 30, 2011
3,896
Las Cruces, NM
What about a Glass/Carbon fork? Easy enough to hand layup over a form and band saw out the shape. This would only take a band saw, drill press, tube bender, courage and determination. (just a sketch, I didn't add bearings are anything)
Grumpy Cynic
7,724
Note the castor and trail of the Durand MkV nose gear as compared to other castoring nose wheels.
deskpilot
Jun 30, 2009
1,131
Whist we've side tracked to castering nose wheels, I'm working on a new design which will have a retractable/castoring nose wheel. My questions are, how to stop shimmy and how to hold the wheel central, and above the nose leg when retracting it rearwards. The leg will have a 'skin/door' attached to it to close the wheel bay. There will be no suspension as such, just a floating hub wheel and balloon tyre, I hope.
Grumpy Cynic
7,724
The BD-5 uses a simple spring loaded ball detente to hold the castoring nose gear in the forward position during retraction.
