WonderousMountain
Think you'll get better fuel consumption with a 3 valve head.
Driven by a single camshaft. Like the block, the block-head
Is probably going to need modification or substitution. Plate
Based case is a good deal. It could even be bolted, depends
on our luck with Gaskets. Planetary redrive might be best, if
going direct drive, the bellhousing can be swapped, I saw a
few interesting Marine ones lately. Although, I guess you'd
need have to consider Bolt pattern first.
