Michealvalentinsmith
Also if I recall the Gossamer Condor used reverse warp much like a PG for roll/yaw.
I do remember something about the 2fl concept being adopted in a powered ultralight - I forget the name now. Later the high wing concept was abandon and it morphed into the Goldwing.
The concept of the high wing was to eliminate canard wake over the mainwing and to suspend the pilot low enough that weight shift was viable for pitch control. The diagrams show the pilot supine but the limited commercial version had the pilot rotate prone on a sliding board.
The idea was to reduce the inherent inefficiency of a canard in that the Cl max of the main wing is limited to a value below the canard - as the canard must stall first. (MaCCready avoided this by simply having the canard stall last - no big deal with such low wing loading and low altitude).
The idea was that with weight shift for pitch the canard could be set at a fixed value only slightly below the mainwing and remain constant since it wasn't required to move for pitch control.
There are some pilots who remain interested in the design who are continuing to research the concept.
The 2fl was recalled by the distributer - Butcher - and reincarnated as an ultralight. The canard was used for pitch and if I recall one version used a slotted canard. This would seem counter intuitive as it would really delay canard stall - but the canard was loaded such that it still stalled first.
