Urquiola
Aug 23, 2013
84
Madrid, Spain
They say the Tesla Flying Saucers were huge size capacitors, energy sent to it with microwave beams. Is the concept of MW recharge available today?
Blseeings +
Urquiola
Aug 23, 2013
84
Madrid, Spain
Sorry, I am not expert in "microwave beams".
I just look for actually available energy sources :)
I'm not that sure microwave beams are not available today as energy transfer way. Do it have any resemblance to the electric teethbrushes charged by putting it on a nail in a base?
See, eg.: 'Wireless energy transfer', 2010: Wireless Energy Transfer
I suppose other documents exist. A German book for young: 'Across the wide world', told about a group of slumber homes near a radio station having light bulbs fed with broadcasting antenna emissions. Blessings +
John.Roo
Oct 8, 2013
329
Letohrad / Czech Republic
Few days ago I found article about wireless charging used on cell phones. It was written that wireless charging decrease battery lifetime.
"Classic charging with a “slow” charger will reduce the battery capacity from 100% to 90% in a certain period of time, wireless charging will reduce the battery capacity from 100% to only 70% in the same period of time."
Maybe is valid only for a LiPo cells, however still interesting to see this comparizon.
The energy transfer from some ground source directly to airplane would be interesting solution.
In the article Wireless energy transfer (the link you posted)
they mentioned microwave and laser beams....
Well... in my opinion it will need also very good research about how this can affect human body. I don´t want to be "cooked" in the cockpit or blind because laser beam (or reflection of laser beam) will damage my eyes.
So... it is a long way of research end development to do energy transfer the way it is safe and approved for aviation.
Best regards!
Martin
henryk
Mar 8, 2010
5,155
krakow,poland
=+ e-soaring ? (6 kW)
=+ HYBRID s...
John.Roo
Oct 8, 2013
329
On Saturday I had a long discussion about the "regeneration" usable in sport aviation.
I personally also beleive that is possible :)
Conversion of electric motorcycle propulsion to light airplane?
Why not. I am not fan of reduction belt (as shown on e-Gull photos), but in case is affordable....
Every electric project counts :)
henryk
Mar 8, 2010
5,155
krakow,poland
-I propose to look onto Conterrotating Propellers=in case of differential gear we can gain
specific thrust circa 1/3 (30 % !)...
(GREEN)=
50 kG =single propeller, 80 kG/ 20 HP =CR propellers, the same diametr...
John.Roo
Oct 8, 2013
329
A bit (hopefully interesting) technical facts about the last two flights with electric Phoenix...
During 153 km / 1h 18min flight from LKTC to LKUO I used energy equivalent of 2,45 lit of MOGAS (0,64 US gal).
During 220 km / 1h 50min flight from LKUO to LKPD and than back to LKUO + "some soaring" I used energy equivalent of 1,62 lit of MOGAS (0,43 US gal).
And I still beleive that would be possible to make it better if:
1) regeneration is used when airplane reach cloud base and if
2) prop is automatically adjusted by servo following best propulsion efficiency (calculated probably from torque and RPM).
and of course if
3) better glider pilot is aboard :)
Best regards!
Martin
4,438
Have you calculated/estimated the drag from the feathered prop?, Wind tunnel?
John.Roo
Oct 8, 2013
329
Unfortunatelly I don´t have possibility to test prop in wind tunnel.
Subjectively I feel some difference but more important is energy saving. Electric motor has no compression like combustion engines (Rotax) so to stop propeller would be normally necessary to use "motor brake". But "motor brake" needs energy so I feel better if I feather prop mechanically. My "ideal" position for gliding = no turning :)
