Selling wooden propeller for Jabiru 2200.
Material - beech.
Protection of blades - fiberglass and stainless steel.
The price - 250 euros.
Condition - new.
Wooden propeller production resumed.
Price is determined individually depending on the material, method of protection, engine power.
The base price - $7 per 1" diameter propeller.
This propeller went to France.
The diameter of the small 1700 mm. Power 160 hp Speed - 232 km/h.
Conventional airfoils are not reached. At low speeds - stall, the low thrust noise. Designed specifically airfoil based on NASA-44. Now everything should be fine - high thrust at the start, a high thrust at speed.
The propeller is covered with fiberglass and clear varnish.
Yes, all the holes are formed.
Diameter - 1727 mm.
The propeller is individually designed to provide high performance RV-9 aircraft.
This is not quite true.
This profile - it is only the basis for the development of its own special profile. This new profile has the necessary properties to ensure the required speed range.
No known profiles do not possess the desired characteristics.
