aviast
Hi all,
I'm sure the current setup, with regards to master switch and keyed ignition, came about after much thought and lessons learned but I'm young(ish) and ignorant of all that so I'm going to propose throwing it out.
Please poke holes in my idea! I've always thought the usual ignition switch wasn't quite right:
During the run-up checks you go through "L" to check the right magneto. It just bugs me. OK I hear you: it's just a minor flaw which allows the ignition to be kept simple.
At the same time, I've always thought that the master switch should have some type of protection to prevent any old person turning it on and flattening the battery.
The key should be on the master switch, not on the ignition!
How, then, to replace the keyed ignition?
With a simple keyed master switch and two switches:
What am I missing? Why isn't this the way it's done? What are your thoughts?
- A spring return toggle switch for the starter motor; and
- A self-centering 3-position toggle or rocker switch installed horizontally so that pushing it left and right grounds the right and left magnetos, respectively.
- You don't have to go through "L" to check the right magneto.
- I've added complexity and weight by replacing two components (master switch & keyed ignition) with three components (keyed master switch, ignition, and magneto selector)
