I think putting only one balance weight (instead of distributed like Cessna) might cause a dynamic torsion issue in the long aileron.
The EZ type aircraft have a steel rod for mass balance in the LE of the aileron, so the weight is constant from tip to root. However, the elevator on the canard has an outboard mass balance and an inboard mass balance that are point masses (effectively). So both types are used. There are apparently many ways to skin the flutter cat... I assume that Burt picked the "point mass" system for the elevator since the canard/elevator combination on these canards is effectively a slotted flap, and there would be no way to shape the slot and LE of the "flap" (elevator) if the mass balance was distributed. Since the ailerons are NOT slotted flaps, a distributed mass could be used.
Both the elevator and aileron are slightly OVER balanced - meaning that when hung from the hingeline, the LE is slightly below the TE. The plans specify how much. Interestingly, if extra weight is needed to balance the elevators, the plans specify to only add it to the outboard position (although I see MANY planes in which it was added inboard - it's almost like folks can't read). Jon Karkow, late of Icon Aircraft and a longtime senior engineer at Scaled, told me that his understanding was that the inboard mass balance weight didn't actually accomplish anything and he didn't know why Burt had put it there - his understanding of flutter theory indicated that all the weight (if not distributed) should have been outboard. He gave me a good explanation for why, but I don't remember it (being old and senile).
So. Is only one balance weight bad? Sometimes not, apparently, since the only elevator flutter instances in EZ type aircraft occurred when the elevator wasn't balanced correctly, but who knows in this case.
You can download a video of canard flutter on a Varieze here:
it's pretty amazing
