Pulley clearance 1/8" cable
Discussion in 'Tube and Fabric' started by Little Scrapper, Jun 14, 2019.
  1. Jun 14, 2019 #1
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,352
    3,276
    Wisconsin
    Imagine a torque tube (control stick) and two steel fittings welded on it. A 2" pulley goes between them. The cable is 1/8" and does a 180° turn on the pulley itself. Clearly it's for the elevator.
    Anything written or documented that would explain the maximum/minimum allowable clearance from the phenolic body of the pulley to the inside of the steel fitting? Attached is a drawing I made to explain it.
    If no documents exist what is the standard practice?
    Thanks
  2. Jun 14, 2019 #2
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,352
    3,276
    Wisconsin
    Here's a quick side shot of the assembly. Regardless of the actual assembly I'd imagine most control pulleys in most airplanes using cable have minimum and maximum allowable clearance right?
  3. Jun 14, 2019 #3
    11,551
    3,231
    I think it’s all about keeping the pulley free. Essentially pulley bearing width or with washer spacers if needed. Space needs to be maintenance friendly at most. You would be adding fences to keep the cable from jumping track so no worry is needed if cable jumps, you have to make it so it can’t.
    Little Scrapper and BoKu like this.
  4. Jun 14, 2019 #4
    11,551
    3,231
    Pops, BoKu and Little Scrapper like this.
  5. Jun 14, 2019 #5
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,352
    3,276
    Wisconsin
    Ok. So no washers. The bearing clearance by itself with no washers, so the difference between the body and the bearing race is .031"
    wsimpso1 likes this.
  6. Jun 14, 2019 #6
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,543
    3,156
    Las Cruces, NM
    There's no min/max gap guidance. 43-13 even talks about *clamping the inner race of the pulley bearing.
    *They (self locking nuts) may be used with anti-friction
    bearings and control pulleys, provided the in-
    ner race of the bearing is secured to the sup-
    porting structure by the nut and bolt.
    wsimpso1 and Little Scrapper like this.
  7. Jun 14, 2019 #7
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,352
    3,276
    Wisconsin
    Thank you.
  8. Jun 14, 2019 #8
    Oct 19, 2003
    5,787
    3,012
    The standard inner race thickness is the spacing you should have. That prevents the cable from falling into the gap while rigging. Then a cable guard will keep the cable on the groove.
  9. Jun 15, 2019 #9
    CharlieN
    CharlieN
    CharlieN
    Sep 7, 2018
    38
    25
    Vermont USA
    One question with this application, a 2" pulley utilized with 1/8 cable is recommended for no more than 15° bend. In your application can you utilize a larger pulley with the cable return run through the torque tube? The 2¾ or larger pulley allows for a considerably more natural bend for the cable. This would offer less chance of the cable to either take a set or try to climb out of the sheave.
    Little Scrapper likes this.
  10. Jun 15, 2019 #10
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,352
    3,276
    Wisconsin
    The 15° they mention is the deflection angle or perpendicular to the body not the 180°direction.
    In this application the angle will be less than 2° I'm guessing.
  11. Jun 16, 2019 #11
    ultralajt
    ultralajt
    ultralajt
    May 10, 2009
    1,560
    747
    Slovenia
    I found this in book Aircraft detail design manual: ADDM.jpg
