There seems to be some controversy in other parts of the HBA about glue and bonding. This poll is for sheet metal workers, as to what you would bet your life on. Would you trust yourself to bonding aluminum correctly in your own build/design project.
1 Glue does not work with aluminum except in highly controlled aircraft factory environments...Rivet or Die.
2 Gluing aluminum is fine as long as you use the right stuff and do it correctly. I bet my life on it.
