Part 103 clarification
addaon
Feb 24, 2008
4,041
Kanab, UT
I've been perusing AC 103-7 and its appendices, and I want to check what I think I know.
First off, assume a "max" UL... empty weight 254 lbs, 5 gallon fuel capacity, 24 lb ballistic parachute, 220 lb pilot, 20 lb payload.
For the purposes of AC 103-7, the takeoff weight of this aircraft is 254 (empty) + 30 (fuel) + 170 (nominal pilot) = 454 lbs.
Now, the "assumed CL_max" is dependent on top camber anyway. Assume no flaps on this beasty; so to fall into the 1.6 category with a two surface wing, "top surface camber" must be at least 7%. Two examples of such airfoils are the 0014 (7% by definition, even though no camber by normal definition) and the 23112 (7.65% upper surface). Let's use the 0014 for discussion purposes.
By chart, the maximum wing loading is about 3.15 lbs/ft^2. At 454 lbs, this comes to 144 ft^2. So 32 ft span by 4.5 ft constant chord gives a nice hershey bar that gives this area.
Would this actually be a legal (for stall purposes) ultralight?
Actual take off weight would be 548 lbs, and actual CL_max would be around 1.4 for a 0014. So actual stall speed would probably be between 28 kts and 29 kts, almost 20% higher than the legal limit. But everything's okay, because I chose to demonstrate by AC 103-7 rather than measured values, yes?
Edit for follow-up question: Does all of this still apply if some characteristic of the plane (tail authority, for example) prevents it from actually stalling, limiting minimum demonstrable speed to 1.3x stall speed?
