Alright then gentlemens, I give you new canard design!
I use a coffe break to make this sketch. I dont want to design something real like that as I am not fan of the canards, but I want to sketch something new..I think I managed.
Dont bother wit cooling air intake location... was just my instant vision....could be different.
Dont bother also with obvious tail heavy apearance. Wing can be moved to match with proper CG.. or wing tips can be sweept backwards a bit...
But it is really new? Did you see anything similar with "split" canards alerady?
I see some benefits from that layout:
- better view forward
- when aproaching to the stall of canards, downwash will hit outer wing panels and lowering their AoA, so ailerons will work good and wingtips will not stall instantly due aileron acutating.
- main landing gear could be installed inside canard booms in the main wing.
- Canards could be mounted with negative dihedral, in line of pilot sight, so minimal area will obstruct pilots view..actually no canard area will be visible from the cockpit...
What do you think?
Go! Dont be affraid to express your opinions!
Aerodynamic thoughts, structural thougts..
I wonder what surprises I am waiting...
Mitja
