Let me read it again.Did you get all that Pops?
How many times do I get to read it ?Did you get all that Pops?
I like the swing out mounts. Especially when having to remove the hard dynafocal mount engines.
Dan
That would make for a strong buzz through the airframe. A lot of racecars and motorcycles are done that way, and you sure can feel the engine. Might have had to bump tube size to stand up to the increased vibration. One other thing about solid engine mounts is that the airframe must then have its lowest natural frequency at least 1-1/2 octaves above max firing frequency or the airframe will resonate with the engine... I do not know if that will require any beefing up of the airframe or not...I think Wittman bolted his V8 solid with no rubber.
Somebody else thinks so too.I had the V-twin rigid base mounted. It shook back and forth with each power pulse. I bolted another additional rigid mount near the top rear and that eliminated the shake. Yes, probably a high frequency buzz now, but the alternative was shake it apart. Different parts resonated at different rpm.
Back in the 1970's, I knew a technician from Denmark who had a master craftsman's card. On his first day of metal working in the apprenticeship program, he was given an irregular shaped chunk of steel and a file. He had to form a cube to some really precise accuracy for a grade, using only the file to shape it.Why go with CNC tube cutting for such a small job. 10 minutes with a cheap HF electric grinder with a 3" for 4" cut-off wheel and a file will do the job for each tube.
Same for an apprentice in Germany.Back in the 1970's, I knew a technician from Denmark who had a master craftsman's card. On his first day of metal working in the apprenticeship program, he was given an irregular shaped chunk of steel and a file. He had to form a cube to some really precise accuracy for a grade, using only the file to shape it.
He said that he worked on it every free moment, and did not get very much sleep.
I'm with you, Pops; often it is better to grab a hand tool and form a part than to diddle around with machine tools.
After a wood dowel mock up I'll have the basics for starting a drawing.Why go with CNC tube cutting for such a small job. 10 minutes with a cheap HF electric grinder with a 3" for 4" cut-off wheel and a file will do the job for each tube.
We had a similar project in A&P class. To familiarize students with hand tools and measurements, you have to make a small ruler/thread gauge/square about 6x3in starting from a random 1/8th thick cut off they purposely did on angles. One corner had to be 90deg and another 45deg. The gauges were 1/8thNF and NC through 1/2in in various pitches. Then mark off 16ths for a ruler.Back in the 1970's, I knew a technician from Denmark who had a master craftsman's card. On his first day of metal working in the apprenticeship program, he was given an irregular shaped chunk of steel and a file. He had to form a cube to some really precise accuracy for a grade, using only the file to shape it.
I'm also working on mounting a V-Twin, on a test stand, but aiming at possibly hanging it on a firewall eventually. I cribbed some ideas for soft mounting from the way Generac mounts these engines in gensets. They "float" the Engine/generator assembly as a unit in soft mounts, which are loaded in shear, kind of along a radius from the crank. The engine is on a "tray", and the "tray" is soft mounted into the chassis of the genset. Part #17 in this view is the isolator Generac 4582-2 Parts Diagram for Generator (jackssmallengines.com)I had the V-twin rigid base mounted. It shook back and forth with each power pulse. I bolted another additional rigid mount near the top rear and that eliminated the shake. Yes, probably a high frequency buzz now, but the alternative was shake it apart. Different parts resonated at different rpm.
