Modern day "motorcycle of the air" aircraft class?
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by cluttonfred, Oct 3, 2015.
  1. Oct 7, 2015 #121
    2,866
    1,600
  2. Oct 7, 2015 #122
    RPM314
    RPM314
    RPM314
    Mar 27, 2015
    724
    301
    NY, USA
    We're talking about this point and how it will eventually fatigue and kill the pilot, you dog. ;)
    I don't get how I was being ambiguous though.
  3. Oct 7, 2015 #123
    rtfm
    rtfm
    rtfm
    Jan 3, 2008
    3,190
    571
    Brisbane, Australia
    ...eventually fatigue and kill the pilot? Sounds pretty ambiguous to me... :)
    Topaz likes this.
  4. Oct 7, 2015 #124
    Starjumper7
    Starjumper7
    Starjumper7
    Sep 28, 2015
    207
    32
    Ecuador
    Yes, its the compact tail end that makes it so nice !! :D
    thanks
  5. Oct 7, 2015 #125
    Starjumper7
    Starjumper7
    Starjumper7
    Sep 28, 2015
    207
    32
    Ecuador
    Not if its a single tube keel frame with fiberglass skin !!
  6. Oct 7, 2015 #126
    RPM314
    RPM314
    RPM314
    Mar 27, 2015
    724
    301
    NY, USA
    Oi vey.
  7. Oct 7, 2015 #127
    Starjumper7
    Starjumper7
    Starjumper7
    Sep 28, 2015
    207
    32
    Ecuador
    This is the feeling we're after. Sitting on the wing.
    ... fast, low altitude, naked ...
  8. Oct 7, 2015 #128
    RPM314
    RPM314
    RPM314
    Mar 27, 2015
    724
    301
    NY, USA
    Wait a minute...those chins on the dragon things......
    Burt Rutan designed their yaw control!
    Topaz and Starjumper7 like this.
  9. Oct 7, 2015 #129
    rtfm
    rtfm
    rtfm
    Jan 3, 2008
    3,190
    571
    Brisbane, Australia
    If sitting ON the wing is what you're after, what better than this:
    It's about as motorcycle-esque as you can get. And WAY cool...
    Duncan
  10. Oct 7, 2015 #130
    Starjumper7
    Starjumper7
    Starjumper7
    Sep 28, 2015
    207
    32
    Ecuador
    Inspired by the ancient legendary Banshee warriors.
    What was this about lack of styling on aircraft?
    With this you could lean forward for high speeds and sit up straight for 'regular' speeds.
    DangerZone likes this.
  11. Oct 7, 2015 #131
    rtfm
    rtfm
    rtfm
    Jan 3, 2008
    3,190
    571
    Brisbane, Australia
    Starjumper, I think you have a really nice looking design here. If you're going for ease (hence, inexpensive, quick) of construction, consider a rectangular wing. One template for the ribs. Easy as. I would also build in a seat back, and fair it in to the aft fuse. Doesn't have to be big. And it would still look very sleek.
    Duncan
  12. Oct 7, 2015 #132
    DangerZone
    DangerZone
    DangerZone
    Sep 5, 2011
    2,107
    370
    Zagreb HR
    :D
    With such a small tail close to the fuselage being in the body wake, it would have very litle authority. That's why the Cri Cri has a T tail, to get above the thrust lines and the canopy turbulence.
    The performance of the Cri Cri without a canopy would depend on power. The Cri Cri is a great little airplane that flies on low powered engines consuming very little fuel because it has pretty decent and well designed aerodynamics. Lose the canopy and you would need about double the power to have the same performance. Which with motorcycle engines isn't hard to achieve, just add a twist of the wrist.
    The canopy does not have to be fully closed to achieve pretty good aerodynamics. With a clever design you might get away with very little additional drag like on racing motorcycles. Thus to answer that question you are on the right track, cause imagination and clever ideas allow new concepts. However, there are usually very few 'new' concepts that haven't been tried before, like in the picture of Tiger Tim whch is quite close to what you had in mind... ;)
    The Hayabusa might be a bit overkill, there are plenty of good 100HPish motorcycle engines from the 80s&90s with a shaft drive that could be used. Get a longer used shaft from a racing car on e-bay, add a centrifugal clutch on it with a prop hub and there you go with least investment. Many of those engines had cylinder head oiling and cooling, you might want to chose one with such design.
    Now, that's much better. :)
    How about getting rid of the twin booms and protruding the tail srufaces from thebottom of the fuselage and the wing from the top? If seating 'inside' the wing with the pilot's back seated on the wingspar you might have good foundations for an excellent design... ;)
  13. Oct 7, 2015 #133
    DangerZone
    DangerZone
    DangerZone
    Sep 5, 2011
    2,107
    370
    Zagreb HR
    If a person wants to save time and not do the ribs in plywood/foam/whatever by hand on a bandsaw then a printer might be a solution for easy and fast making of tapered ribs.
    [video=youtube;Yz10C0U6tM0]http://www.youtube.com/watch?v=Yz10C0U6tM0[/video]
    However, a skilled homebuilder might cut out all the ribs of a tapered wing in one single day on the bandsaw.
  14. Oct 7, 2015 #134
    6,365
    2,231
    Glad to see this still going, I like Starjumper7's sketch with or without the girl and despite my usual "keep it simple" mantra I think the tapered wing might be justified here.
    I still have mixed feelings about a head-forward racing motorcycle seating position and how that would work in terms of a seat harness. I know motorcycles don't have one but I would feel pretty uneasy without one a few thousand feet in the air.
    I know I mocked the BMW C1 semi-enclosed motorcycyle, and it's certainly not as sexy as riding hunched over on a ninja bike, but I don't know how you would wear a safely harness in racing position.
    This does also bring to mind that an open-sided aircraft designed for minimum drag and buffeting with no dies but with optional doors for cold climates might be an interesting approach as well. Air-scooter rather than Air-bike?
  15. Oct 7, 2015 #135
    I spent about 2 months once working out an engine geometry that would give me linear motion (ie. I could use a pair of opposing pistons rigidly connected). Yes, somebody had already come up with the same solution I did - in 1877 - The Parsons Epicyclic Engine.
    Check the animations (about 2/3 down the page).
  16. Oct 7, 2015 #136
    6,365
    2,231
    I sure hope we could come up with something better looking that that. I wish James Wiebe much success, but that thing is hideous.
    rtfm likes this.
  17. Oct 7, 2015 #137
    DangerZone
    DangerZone
    DangerZone
    Sep 5, 2011
    2,107
    370
    Zagreb HR
    If we're talking about a single seater, the seating position can be variable. On custom bikes there is an option to make the bike 'triseating'. I tried it on a bike years ago, ergonomically it can work great. Custom bikes are usually exposed so at highers speeds it is good to have an additional seating option to better adapt to speed and riding regimes. This is an animation where one could get the idea what a 'triseating' option on a bike is.
    [video=youtube;LHo6c7w2TWY]http://www.youtube.com/watch?v=LHo6c7w2TWY[/video]
    The upright position in the video is a bit exaggerated because the final standing ramps usually have much 'milder' angles but this is only for people to get the idea how this is done.
  18. Oct 7, 2015 #138
    rtfm
    rtfm
    rtfm
    Jan 3, 2008
    3,190
    571
    Brisbane, Australia
    I have to agree with you, on all three counts.
    Duncan
  19. Oct 7, 2015 #139
    ultralajt
    ultralajt
    ultralajt
    May 10, 2009
    1,566
    750
    Slovenia
    Interesting, how much we are ready to talk, discuss, and brings all sorts of visions and ideas (look how fast this tread grow) about the vehicle, we all know somwhere in the back of the minds, that it will never became reality.... :)
    I suppose, we all like to dream.... :)
    I am very much attempted to model my idea (hand drawn sketch some pages back) in 3D computer graphics, just to bring 2d idea to "3D life". ;) :p
    Topaz likes this.
  20. Oct 7, 2015 #140
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,611
    174
    There are a few motorcycle style designs out there, or which might be worth to be reengineerd!
    - Belite's SkyDock with a narrower Fuselage
    - the existing ZJ- Viera
    - some of Beaujon's designs
    - Cloudster
    - F-U.... Design of Topspeed100
    - Aeromax
    - POC of Ivanovaero
    - Airbike
    - Hovey Whing Ding and Betabird
    - Windy3
    Anyway, for a good looking sit on top bird, that is affordable to build and easy to fly, my ideal would be something like the fuselage construction, not the design, like the Hovey Beta Bird and the Windy 3 and a wooden lowwing like the Viera.
    Further the wings should be either foldable or quick removing.
    If the design requires a fixed or retractable gear that would be fine but not necessary.
