Homebuilt metal forming tools
Discussion in 'Workshop Tips and Secrets / Tools' started by Othman, May 26, 2006.
  1. Aug 31, 2006 #21
    Jman
    Jman
    Jman
    Site Developer
    Oct 22, 2002
    1,921
    53
    Pacific NW, USA!
    Yep, finding some interesting stuff. Thanks.
    Jake
  2. Jan 17, 2007 #22
    base363
    base363
    base363
    Nov 6, 2006
    81
    In the absence of expensive brakes and shears. Harbor freight sells a pretty good brake for about $100.
    For cutting aluminum, Andy Snips do a pretty good job. Around $30. They cut left, right and straight, and don't leave the rough edges that aviation snips do.
    http://www.jumprunenterprises.com
  3. Jun 8, 2008 #23
    GESchwarz
    GESchwarz
    GESchwarz
    Oct 23, 2007
    1,152
    92
    To keep your saw blade from getting gummed up with aluminum, touch it a little when it's spinning with candle wax.
  4. Jun 8, 2008 #24
    Moderator
    Apr 4, 2007
    8,457
    2,855
    They sell stick wax specifically made for cutting. I use it; I honestly don't know whether it works better than candle wax. The stick wax is also great for putting in long wood screws.
    When I built my PPG (lots of cuts of 1" square and round alum tubing and 1/16" and 1/8" sheet) I did almost everything with my radial arm saw with a blade (from McMaster) specifically made for aluminum and plastic. Worked quite well, got quite hot, and you want to push, not pull, the blade into the sheet. Sucks on plastic, though, no matter what they say. I've since picked up a light band saw for light metal and plastic cutting, and will now only use the radial arm saw for wood and alum tubing.
    I lust after a mill... currently I make do with a good Rockwell table drill press my father gave me and a cheap cross slide vise (so cheap the slides are a few degrees out of perpendicular!)
    -Dana
    P.S. You can build a phase coverter with a motor and some big capacitors; one of my co-workers did it. I don't have the details but doubtless you can find it on Google.
    Space isn't remote at all. It's only an hours drive away if your car could go straight upwards.
  5. Oct 15, 2008 #25
    Becca~T
    Becca~T
    Becca~T
    Oct 10, 2008
    8
    0
    Oregon
    I found this page some time back to build a home built break.
    I was thinking of building one.
    I opted to buy one from a car shop that closed its doors, For cheaper than the required parts to build the break.
    But here is the link for anyone who wants to not only build a Airframe at home, But there tools as well. :)
    ~Home Built Break~
  6. Oct 15, 2008 #26
    djschwartz
    djschwartz
    djschwartz
    Jun 22, 2008
    982
    93
    Portland, Oregon
    Check out Craig's List in your town. I bought an older but very capable industrial TIG welder that way for a very good price. And it came with a lot of useful accessories that all would have be extra if purchased new.
  7. Oct 15, 2008 #27
    kent Ashton
    kent Ashton
    kent Ashton
    Aug 15, 2008
    714
    201
    Concord, NC
    Lot's of homemade tool ideas here
    Tools
    -Kent
  8. Oct 16, 2008 #28
    Mad Man Mike
    Mad Man Mike
    Mad Man Mike
    Oct 2, 2006
    61
    0
    Buckeye AZ
    Several years ago I built an 8' long brake for bending light steel and aluminum. I was at my Son in Laws work ( Machine Shop at
    Luke AFB ) and took several pictures of one they had. I went home and duplicated it out of steel from the salvage yard. It works excellent and bends up to .050 x 96" long Aluminum with ease. It will beng thicker Aluminum if the pieces are shorter. With steel it is not as good with the long pieces but it still works well in most cases. I'll take a picture of it and post it--it hasnt been painted so it looks a little rusty --but hey it works -I'll try and edit this post to put in the pix in a couple of days--
    Now if I could only find an 8' foot long blade I would attempt a shear--
  9. Oct 24, 2008 #29
    billyvray
    billyvray
    billyvray
    Aug 17, 2005
    690
    212
    Newnan, GA
    Here's a neat little pamplet pdf from the cri-cri builders I found.
  10. Jan 13, 2009 #30
    BAILEIGH INC
    BAILEIGH INC
    BAILEIGH INC
    Dec 17, 2008
    66
    3
    Manitowoc Wisconsin
    I have seen plenty of our fabricating customers make their own brakes. Not sure on the shear though, other than a throatless shear, but then it would be up to you to keep it straight.
  11. Apr 24, 2009 #31
    drichers
    drichers
    drichers
    Apr 22, 2007
    5
    0
    I use a standard metal cutoff blade on a cheap Skil saw. I clamp a long stiff metal straight edge on the 4x12 2024-T3 sheets. (I cut 2 - 0.065 thickness sheets simultaneously).
    The sheets are placed on top of 2x4 boards on top of saw horses. Removable
    clamps are placed strategically to keep the 2 sheets from slipping.
    Wear safety glasses and ear plugs. Also, go slowly.
  12. Jun 9, 2009 #32
    base363
    base363
    base363
    Nov 6, 2006
    81
    To make long, straight cuts in aluminum sheet, many homebuilders us a P-800 Olfa knife.
    http://www.olfa.com/UtilityKnivesDetail.aspx?C=46&Id=58
    You tape a straight edge to the sheet, so you are covering the part you want to use. Then score the sheet with the knife about 8 or 9 times. (Depends on the thickness)
    Next, move the score to the side of the table and bend it over. It will snap off with a very clean cut. Just like a sheer.
    It can also be used to cut access holes and such.
    Make sure you buy the P-800 knife, as it’s the only one that works for this.
    Colin
    A/P IA
  13. Jun 9, 2009 #33
    Midniteoyl
    Midniteoyl
    Midniteoyl
    Sep 4, 2003
    2,417
    500
    Indiana
    I use a Stanley box knife for scoring and snapping thin sheet metal and aluminum.... fairly common practice.
  14. Jun 9, 2009 #34
    addaon
    addaon
    addaon
    Feb 24, 2008
    1,689
    100
    San Jose, CA
    I've used a Stanley and the P-800... they P-800 is worlds above. You're not scoring the sheet, you're digging a perfectly straight, several mil wide and deep section right out of it. With patience, you can cut 0.040" 2024-T3; and surely more, but that was the limit of my need and my patience.
  15. Jun 10, 2009 #35
    Midniteoyl
    Midniteoyl
    Midniteoyl
    Sep 4, 2003
    2,417
    500
    Indiana
    Cool... gonna have to try it out.
  16. Jun 13, 2009 #36
    Jman
    Jman
    Jman
    Site Developer
    Oct 22, 2002
    1,921
    53
    Pacific NW, USA!
    The P-800 is all the rage on the Zenith lists. I really need to pick one up with all the parts I'll need to make to replace factory parts I'm sure to ruin at some point.
  17. Jun 18, 2009 #37
    lr27
    lr27
    lr27
    Nov 3, 2007
    3,216
    463
    For pieces that have a bit of stiffness, there's a tool called a timesaver which is pretty good for dressing up edges, though a file works ok too.
    I'm wondering if you temporarily glued or taped your aluminum to some cheapo board material if it wouldn't be easier to saw.
    If you have a piece that's driving you nuts, you might try having it cut by a sheet metal shop. At least if you have or can make CAD drawings. Might not be all that expensive. Also if you have a bunch of identical pieces. The set up costs quite a bit, individual pieces not so much.
  18. Jul 11, 2009 #38
    vortilon
    vortilon
    vortilon
    Jul 7, 2009
    453
    5
    Marana AZ USA
    With all the job shops going TU right now you'll find your local machine tool dealers willing to make great deals on used equipment of all kinds.
  19. Feb 11, 2010 #39
    Moderator
    Apr 4, 2007
    8,457
    2,855
    I know this is a pretty old thread, but... I'm working on the wing structure design for my biplane project and I've just about concluded I need a long (8') brake. A little googling finds this thread on the Biplane forum. The link in the second post looks promising.
    My wing has two tube spars (and foam ribs with aluminum capstrips), but a bent up C-section of very thin aluminum seems to make the most sense for the back of the wing at the aileron hinge line, and also perhaps for the leading edge of the ailerons. I considered bent C-channel spars instead of the tubes, but I don't trust the accuracy of a homemade brake... any variation could lead to buckling under load.
    Of course, if the trailing edge is non structural, I could do it in short sections from rib to rib.
    I may also bend up light angles to support the back end of the false ribs. In this case, it'd have to be one piece to maintain sufficient rigidity.
    -Dana
    Dullard: someone who can open an encyclopedia or dictionary and only read what they'd planned to.
  20. Feb 11, 2010 #40
    BoeveP51
    BoeveP51
    BoeveP51
    Jan 25, 2008
    97
    10
    Spring Hill, FL - formerly W. Ossipee, NH
    For those looking for plans to build an 8' brake try the following:
    Mac's Machine & Design
    Look down the left hand side for bend brake. He charges for the brake plans but they are excellent. I have a copy and once I find the metal source I will be building one. Check it out
