pylon500
Would point out that just 'large head pop rivets' is not really suitable as the heads will chew through the fabric, the large plastic washers are a slightly better idea, but fiddly and expensive when you start buying two or three hundred of them!
My usual (before I found the Foxbat method) way is to lay the fabric glued around the edges, give a light shrink till flat, dope a pre-ironed, one inch wide pinked strip along the rib, then run a length of half inch wide fibreglass reinforced packing tape along the rib.
Using a scriber, locate the riveting holes and prise the fibres of the tap and the fabric aside and insert large head rivet.
Finish with a two inch pinked fabric strip and final shrink before dope layers.
I've never tried stitching...
