810 Briggs Rabbit Hole - New Head Branch
Nov 14, 2009
9,985
Rocky Mountains
Forked off from another industrial engine thread.
Decided to take a few hours to see how much potential a new head casting for the 810 B+S engine might open up. The sketches below have all of the essential original B+S parts in their original location (+/_ 1mm or so).
The block in the assembly is the standard B+S ParaZoom block as found on GrabCad - not the 810 block.
What I think I discovered is that there is some improvement available for aircraft use but a lot of the orientation of the ports depends on if the engine is going to be used upright, inverted, and if the flywheel side will be facing the incoming air or if it is on the trailing side.
I'm not likely to get time to be serious about this project for a year or more but I thought others might like to see how much open space there is available for additional cooling once the OEM restraint for a simple die casting is removed.
810 with vert bare block.JPG810 head valley side.JPG810 head flywheel view.JPG
Edit: Exhaust ports shown are best for inverted. Upright would probably be rotated 90 deg.
