Your thoughts on using a hammer and modified bolt to set solid rivets?
Discussion in 'Hangar Flying' started by Nickathome, Jan 18, 2015.
  1. Jan 19, 2015 #21
    dcstrng
    dcstrng
    dcstrng
    Oct 17, 2010
    912
    321
    VA or NoDak
    The Monnett birds have been built that way for decades -- not, sure but I think the Sonex still describes the "bolt" method for scratch builders (would have to dig out my plans -- stored, decided to built an "alternative..."), in any case certainly for the Sonerai... it works, but I'm using the Avery C-Frame...
  2. Jan 19, 2015 #22
    Nickathome
    Nickathome
    Nickathome
    Sep 29, 2009
    758
    75
    S.E. PA
    I used the bolt method when I was at the Sonex plant and took their weekend course. I have the project I made there as proof the bolt method works, and take no time to learn. The punch is just a big bolt with a concave head ground into it an polished to match the rivet head. You set the project onto a piece of heavy flat steel or a bucking bar and a few wraps with the hammer sets the rivet and it does a nice job.
    I do like the C-frame tool, but for what one costs, I may as well just buy the rivet gun set.
    Looking at the plans again last night, I underestimated the amount of rivets I will need to buck. Looks to be more like 400, so I still may consider a rivet gun..
  3. Jan 19, 2015 #23
    Turd Ferguson
    Turd Ferguson
    Turd Ferguson
    Mar 14, 2008
    4,552
    1,552
    Upper midwest in a house
    You can always rent a rivet gun
  4. Jan 19, 2015 #24
    11,405
    2,092
    So you are hitting the round manufactured head of the rivet.
    I hit the other end, and so can see the rivet form as I hit it.
  5. Jan 19, 2015 #25
    wally
    wally
    wally
    Apr 1, 2004
    926
    14
    southwest TN.
    Did you know that those el-cheapo muffler hammers use the same diameter rivet sets?? You used to buy them for about $10 and get some muffler tools with it.
    And they work pretty good on smaller rivets. I even took one of the muffler cutter tools that comes in the kit and made a flat rivet set. I cut the end off and welded a small round piece of steel to it. Then some grinding and a little polishing with wet-or-dry paper, it will do flush (countersunk) rivets too.
    dcstrng likes this.
  6. Jan 19, 2015 #26
    6,663
    5,545
    I have set thousands of 3/32" rivets with a $8 muffler air hammer. I also welded up my own Avery style C frame many years before Avery sold them. Great for dimpling wing skins. My best flutting pliers are a set I made using Vice-grips. With Vice-Grips you can set the depth of the flutes the same if you want.
    Dan
  7. Jan 19, 2015 #27
    Vision_2012
    Vision_2012
    Vision_2012
    Apr 21, 2010
    274
    122
    Shady Cove, OR
    SPA also has a nice write up of using a Cleveland DIENQ dimpling tool. Dan Weseman is a well informed and patient instructor. I met Dan at Corvair College 23. I used his fifth bearing toolkit in installing his retrofit 5th bearing in my Corvair engine.
