WW II production and engineering cost
Discussion in 'Hangar Flying' started by autoreply, Oct 6, 2012.
  1. Dec 4, 2012 #21
    Powerandpassion
    Powerandpassion
    Powerandpassion
    Dec 4, 2012
    3
    1
    Melbourne, Australia
    Aircar I am based in Melbourne and would love to know about the Hawker Demon in your shed - A1-8?
    Attached pics, if I get it right, are Hawker Demon spar section, with booms formed from high tensile steel strip in an 11 pass strip former. The metallurgy, run through a babelfish from 1930's British Aircraft Standards, is basically US 4140, which you can only seem to find in high pressure gas pipeline material today. All the revheads making tubular racing car frames say they have climbed to the top of the mountain using 4130, which is quite available, but it seems to me that what the aircraft engineers were doing in the 1930's with lightweight 4140 sections was, and still is, exotic, fantastic metallurgy. In a biplane with struts joining wings different parts of the wing spar were subject to greater forces, and this was accomodated by inserting additional sections of tube inside the spar boom, to thicken the section. Sometimes you see old bridges, where a beam section is composed of hot riveted plates, with more plates laid together in stressed sections. These engineers were pushing the boundaries of materials performance, working with exotic new materials while borrowing concepts from the comtemporary age of steam. Another pic shows spar with aluminium ribs attached. There is a fantastic amount of componentry in these wings. I do understand that riveted construction is more reliable in a stressed structure than welding, because I keep reading about welded submarines that leak, work with riveted vibrating quarry screens and fly by preference riveted Boeings. I do also subscribe to the theory that in the 1930s, if an aircraft component could be designed to be manufactured using 10 man hours, it was redesigned to take 50 man hours. I guess that the explicit goal of the German military industrial complex was to employ folk, and it would not have been too much different in the United States. If you put a 1930's design Curtiss Kittyhawk tailplane assembly next to a 1940s North American Mustang tailplane assembly, the manufacturing story has reversed, driven by skilled labour scarcity.
    I think scarcity drives manufacturing efficiency. The designer of the Mitsubishi Zero, hampered by a lack of high power engines, broke down his design into pieces 1/20,000 of the target weight, and strove to find weight savings in components at this atomised level. He created a fantastic, fearful aircraft that dominated the skies in the Pacific in the first half of the war, but thankfully for Democracy could not survive battle damage or dive after American planes built like warships.
    The occupation by Japan of most of the global rubber resources in Malaya created a critical problem of scarcity for the Allies in sourcing tyre rubber. I think the greatest manufacturing efficiencies and cost gains came from standardization. Instead of every aircraft or truck having a unique wheel or tyre the Army Navy code (AN) created standard tyres that could be used across a range of aircraft. AN codes covered everything from bolts to oil filters. It took a long time to create and develop a bureacracy to identify these issues and develop solutions. Known reliable engineering solutions such as the Rolls Royce (Packard) Merlin V12 engine, Browning machine gun, Pesco fuel pump and Lockheed (UK) hydraulics were propagated across many aircraft types and manufactured in the UK, US, Canada and Australia.
    All these standard bits wound up in places with different conditions. With bombs falling on England the 'Shadow factory' was the explicit policy, with numerous, small, dispersed, component manufacturers de risking the system of aircraft manufacture. Even the final assembly of a particular aircraft design was dispersed among a number of factories. It could not grow to the scale of US or Canadian manufacture, but it worked. In the US, free from bomb damage, massive centralised complexes like Boeing, employing thousands, could eventually create colossal scale and efficiency. It is interesting to observe, that when Soviet ICBM could finally reach the US, the Eisenhower administration, via tax breaks, supported the dispersal of American industry. When you drive through some small town in America, and come across a global scale factory making things in the middle of nowhere, it makes no sense until you accomodate this. At least that was the case when I drove through America in the late 90s, when it still made things.
    No question of manufacturing efficiency can be considered in isolation to the conditions in the environment where the manufacturing occurs. It was the explicit policy of British Bomber command, after failing earlier in the war in accurate, pin point attacks on sensitive manufacturing 'bottlenecks' like ball bearing works, to inconvenience the German worker. It was reasoned that if the German worker could not have a hot cup of tea in the morning or a hot shower after work, or if he could not catch a tram to work, the ball bearing factory would soon fall idle. So basic infrastructure was targetted, most vividly the example of the Rhur Dams, and every day railway locomotives. It worked. Poor old Ferdinand Porsche had to work out of a barn in a forest. You cannot compare the magnificent efficiency of Boeing in Seattle, North American in California or De Havilland in Downsview, Canada without some recognition of the De Havilland worker in Halton in the UK running from a lathe and cowering in a slit trench a lot of the time. Its a wonder that anything was made in wartime Europe at all.
    Demon spar.jpg Hind wing.jpg War is cruel, but it would have been a fantastic time to be an engineer.
    Detego likes this.
  2. Dec 5, 2012 #22
    Kyle Boatright
    Kyle Boatright
    Kyle Boatright
    Nov 12, 2012
    864
    490
    Marietta, GA
    Late war P-51's had a contract price in the low $50k range, but that did not include the GFE - Government Furnished Equipment like the engine, prop, radios, and guns. Those were on separate contracts. North American (or whoever) was paid $50k+ to build the airframe and install the GFE.
  3. Dec 5, 2012 #23
    Sep 18, 2008
    5,020
    2,188
    Seems to me that many light aircraft (early Cubs and T-Carts and so on, maybe) were made of 1025 or even 1020 tubing. Strong enough for 75 MPH airplanes.
    Dan
  4. Dec 5, 2012 #24
    Sep 18, 2008
    5,020
    2,188
    What would that be in today's dollars? It would be interesting to compare it to the average Joe's income of, say, 1944.
    Dan
  5. Dec 5, 2012 #25
    Super Moderator Staff Member
    Apr 4, 2007
    8,840
    3,184
    Or faster. The primary failure mode for many truss structures is elastic column buckling, not tensile or compressive failure. Elastic buckling depends on the material's modulus of elasticity, not the tensile or compressive strength, and the modulus is the same for all steels regardless of their tensile strength.
    I do know that prewar T-Crafts had 1025 fuselages while postwar models used 4130. This may have been a matter of material availability, or to use materials consistent with other areas where the stronger alloy may have been necessary.
    -Dana
    If cars had followed the same developmental path as computers, a Rolls Royce would cost $100, get a million miles per gallon and explode once a year, killing everyone inside.
  6. Dec 5, 2012 #26
    Kristoffon
    Kristoffon
    Kristoffon
    Sep 4, 2009
    348
    20
    Brazil
    $500k ballpark
  7. Dec 5, 2012 #27
    Detego
    Detego
    Detego
    May 29, 2012
    470
    105
    North America
    Priced as shown with 4%, per year inflation: $838,472.00
    "If the American people ever allow private banks to control the issue of their currency, first by inflation, then
    by deflation, the banks and corporations that will grow up around them will deprive the people of all property
    until their children wake up homeless on the continent their Fathers conquered." - Thomas Jefferson
  8. Dec 6, 2012 #28
    PTAirco
    PTAirco
    PTAirco
    Sep 21, 2003
    3,501
    1,013
    Corona CA
    Less than a million bucks for a state of the art fighter airframe - try selling that to today's military establishment. Wouldn't go over too well with military contractors: "Fighters must cost tens and hundreds of millions! Hell, why not a billion or two while we're at it...."
  9. Dec 14, 2012 #29
    Hoody
    Hoody
    Hoody
    Dec 14, 2012
    1
    0
    UK
    As stated in several of the previous posts most of the furniture factories around here were switched to aircraft manufacture. And those that weren't switched to arms manufacture of various other varieties. (guns/ tanks etc) the factory my grandparents worked in during the war produced wings for Wellington bombers. and several of the others just down the road from where i am sitting now produced parts for the Mosquito's.
  10. Dec 15, 2012 #30
    PTAirco
    PTAirco
    PTAirco
    Sep 21, 2003
    3,501
    1,013
    Corona CA
    My English grandmother worked on Frazer-Nash gun turrets for Lancasters. My German grandmother was on the other side keeping the homefires burning, while my German grandfather was in some trench in Russia. It's a weird world.
  11. Dec 15, 2012 #31
    Detego
    Detego
    Detego
    May 29, 2012
    470
    105
    North America
    Burt Rutan commented: his ARES (Mudfighter) Design was to cheap to be produce Commercially!
  12. Dec 15, 2012 #32
    PTAirco
    PTAirco
    PTAirco
    Sep 21, 2003
    3,501
    1,013
    Corona CA
    ...and being cheap, had zero hope of being bought by the US government.
    delta likes this.
