When can I get this?
PTAirco
Sep 20, 2003
3,648
Corona CA
The material in the picture is an aluminum extrusion. 1/2 angle, 1/16"thick but with an extra small " bulb" sticking out of the corner.
It is used in the rib caps of a certain unmentionable Cub clone.
I looked everywhere, but nobody else seems to use it. If anyone here has come across a supplier or knows where to get it, I would really appreciate it.20200131_172305.jpg 20200131_172305.jpg
9,575
Try the TW Metals catalog. Or whatever became of TW metals by now, probably some other name. They have a large number of aircraft extrusions, and hold the extrusion dies for several Boeing and Cessna parts.
12notes
Aug 27, 2014
1,237
Louisville, KY
If you have no luck finding it, either look for T section, as TFF said, I section, or get 1/8” thick and set up a router/mill.
13,875
IIRC, we used to get our metals from M&K Metals in Gardena when I was rebuilding WW2 fighters at Chino. If they didn’t have it, they could usually get it.... that is if I’m remembering the correct metal supplier.
