What Kind of Country Have We Become...
13,084
The FAA operating limitation for EA-B requires a category and class for the pilot in command. So for a RV-9 would need a Private Pilot with Airplane rating.
For Sport Pilot you would need a Sport Pilot certificate with a logbook endorsement for Category, class and make and model. 5 hours solo flight required (61.313).
I don't understand the reason for this solo limitation. It is contrary to the FAR that allows solo flight without a rating in Experimental aircraft.
jedi
Aug 8, 2009
2,080
"What Kind of Country Have We Become....." broken The CFR 14 limitation was reduced to solo when Sport Pilot was adopted. Prior to Sport Pilot there was no limitation. It is further restricted by the operating limitations so FAA can provide proper oversight and control.
Long live Ultralights. As indicated earlier in the thread we could have asked for 500 pound UL in Part 103 but but certain manufacturers objected. You got what they asked for. You can ask for more but will not get a 103 revision. Go to the UL organizations or the FAA for a waiver.
The big limitation of the 254 pound limit is a chain around the neck of potential ready to fly manufacturers of UL type aircraft. Sell 1,000s of 270# high performing ULs and the FAA can shut you down or require certification of the design manufacture and piloting of the craft. Better to build a motorcycle of the off road variety (as in air).
61.31 (l) Exceptions. (1) This section does not require a category and class rating for aircraft not type-certificated as airplanes, rotorcraft, gliders, lighter-than-air aircraft, powered-lifts, powered parachutes, or weight-shift-control aircraft.
(2) The rating limitations of this section do not apply to—
(i) An applicant when taking a practical test given by an examiner;
(ii) The holder of a student pilot certificate;
(iii) The holder of a pilot certificate when operating an aircraft under the authority of—
(A) A provisional type certificate; or
(B) An experimental certificate, unless the operation involves carrying a passenger;
(iv) The holder of a pilot certificate with a lighter-than-air category rating when operating a balloon;
(v) The holder of a recreational pilot certificate operating under the provisions of §61.101(h); or
(vi) The holder of a sport pilot certificate when operating a light-sport aircraft.
There are two outs above. Notice there is not a solo requirement only no passenger. A student pilot receiving flight instruction from a CFI
is not a passenger.
Experimental conditions and limitations issued with the aircraft still apply. The conditions can be amended to allow flight without the Category and Class pilot certificate if there is good reason. The Sea Era is a current example. ASES certificate is not required. A majority of pilots who have flown the aircraft did not have a seaplane ratting.
Older experimentals may not have the Category and Class limitation. Do not loose your older Conditions and Limitations. If you ask for a replacement it will have the Category and Class limitation.
13,084
I was assuming Operating Limitations overruled FAR61.31. Need an opinion about which is supreme?
Sort of like how FAR43 doesn't apply to EA-B. But the Operating Limitations does include FAR43 appendix D.
So, what was a good reason to get the Sea Era operating limitation amended?
I have an unfinished Avid Amphibian. Can I supply a reason to avoid the limitation at inspection?
Turd Ferguson
Mar 13, 2008
5,035
Upper midwest in a house
If you are referring to limitation #17 (which references category/class rating), that limitation is applicable only to aircraft that are over 12,500 lbs or turbojet / turbofan powered.
Limitation #18 says PIC is required to have a pilot certificate or authorized instructor's logbook endorsements for solo flight. Limitation #18 applies to most EAB aircraft as a standard operating limitation.
That means a student pilot may fly an EAB solo with the proper solo endorsements in his logbook from an authorized instructor. Otherwise, the student could not complete the requirements for a pilot certificate.
Turd Ferguson
Mar 13, 2008
5,035
43 Appendix D is "Incorporated by reference" i.e. a document (operating limitations) specifies technical standards (CFR43 Appendix D) which now become enforceable.
13,084
Both Limitation #17 and 18 is on Todd Stovall's RV10.
See post 13 here: http://eaaforums.org/showthread.php?7992-Medical-for-Experimental/page2
Turd Ferguson
Mar 13, 2008
5,035
Nonetheless, limitation #17 does not apply as this is not an aircraft that weighs more than 12,500 lbs or is turbojet / turbofan powered. Older OL's had a note that stated that; perhaps framed out of the picture in that example.
There's nothing to prohibit a student pilot from flying solo in a EAB airplane, unless of course it's jet powered which is probably why the OL's have evolved to this point. The FAA's is not going to allow student pilots to get signed off for solo in their SubSonex.
11,056
Not a question about the regulations, but about relative difficulty of piloting.
Wouldn’t a SubSonex, or other simple turbojet aircraft, actually be easier to learn to fly than a piston engine propeller powered version of the same airplane? No P factor and only one go lever are simplifying factors, slower power-up response is a complicating factor. What say those of you with turbojet experience?
Turd Ferguson
Mar 13, 2008
5,035
I say a low time student pilot would have a lot of trouble trying to manage that kind of speed and energy.
They could certainly be trained but by the time they are proficient enough to solo they would have enough hrs to get a pilot certificate.
11,056
It seems to me that higher landing speeds, learned from the very start of flying, would be easier than learning slow speed landings. But that might just be me.
Thanks for your response.
12,800
I think it's much easier to land fast vs slow. Depending on the engine, jets have lag. Drop the power too low and you might not have it when you demand it. I believe a Citation lands at a similar speed as a Barron, but go around is much easier in the Barron. Pull the power all the way back in the Citation, and you are landing. Probably 10 second spool up from idle to full power. Hitting the speeds are more critical because of that, not the general aerodynamics.
Turd Ferguson
Mar 13, 2008
5,035
Quantify "easier" If one only has experience landing a fast plane, that is all they would know so it would be easy to them but it would take a while to reach the "easy" level of proficiency.
There was a study done in the '80's (I think J.Childs) not necessarily related to landing speed but it compared the level of difficulty of a flat approach, the kind typically flown by jets and fast(er) airplanes, to a steep approach (the kind flown by light planes) and it was concluded the latter can be mastered with much less training and practice.
At work I train pilots new to jets where all they have flown is a straight wing piston plane. It's kinda comical. I'd say 1/3 actually reach required proficiency in 30 hrs of OE, 40 hrs is more common, there was one pilot they allowed >80 hrs of OE and he finally did okay. I'm pretty sure it would not take that amount of training going the other way, from fast to slow.
jedi
Aug 8, 2009
2,080
The FAA Inspector also said all new certificated EA-B would include the operating limitation that requires a pilot certificate, category and class.
So a student pilot couldn't solo a properly certificated 280 pound EA-B. So the new pilot would need to find a Light Sport instructor with a two seat Light Sport Airplane, get the training, take a check ride and pay the fee..... get a BFR every two years somewhere....
Or fly slightly illegally under FAR103 because the step to EA-B is too steep.
bill,
if if necessary I can help with light sport sea endorsement.
7,420
I'm going to learn slow. Experience in other vehicles is that it hurts less if you are going slowly when (not if) you don't quite get it right...
don january
Feb 10, 2015
2,797
Midwest
I have a idea for you pictsidhe. Get a hold of chopper girl and the two of you can get her plane Dorthy in the air and look for who finds the "When" first. All the football gear and pads don't help much rather at 50 mph or 150. Heck if ya feel real gutsy jump a train and watch for a tree coming on the side of the tracks and jump! :shock: Tell me then the difference between a soft landing or hard.:gig:
13,084
mcrae0104
Oct 27, 2009
3,260
I stumbled upon something in FAR 61.51(b)(2) where it seems to define "Solo" as not being "Pilot in command".
BB, a solo student is the PIC (see 61.51(e)(4)) but I think the point of 61.51(b)(2) distinguishing between solo and PIC is to record a type of training experience. Although listed separately, solo is a subset of PIC.
FAR 61.51(e)(4) said:
(4) A student pilot may log pilot-in-command time only when the student pilot -
(i) Is the sole occupant of the aircraft or is performing the duties of pilot of command of an airship requiring more than one pilot flight crewmember;
(ii) Has a solo flight endorsement as required under § 61.87 of this part; and
(iii) Is undergoing training for a pilot certificate or rating.
Turd Ferguson
Mar 13, 2008
5,035
"Pilot in Command" is defined in FAR 1.1. When the OL's of an EAB aircraft say "pilot in command," they are referring to FAR 1.1
14CFR61.51 only regulates when one can write "pilot-in-command time" in their logbook.
Those are completely separate concepts.
13,084
Correct. So read the definition of "Pilot of command" in FAR1.1 (Solo isn't defined).
For Pilot in command it says: "(3) Holds the appropriate category, class and type rating, if appropriate, for the conduct of the flight."
So translating that, I think the "appropriate" requirement for solo flight as a Student pilot is only a Student pilot certificate and endorsement, no class rating. So why can't a Private Pilot exercise the privileges of a Student Pilot and fly solo without a class rating?
Now, whether or not a Private Pilot needs a solo endorsement to fly without a class rating, is still unclear to me.
