henryk
Mar 8, 2010
6,517
krakow,poland
John.Roo
Oct 8, 2013
1,092
Letohrad / Czech Republic
Maybe I am wrong, however seems to me that eDA40 (based on DA40) will be operated as two seat airplane and Diamond will use weight reserve of two rear seats to install more batteries.
Makes sense to me - eDA40 is aimed to training segment (pilot schools) and they want to achieve endurance 90 min.
Interesting is also supplier of bateries.
Each box has following parameters
  • Voltage at Charge: 44.5 V
  • Nominal Discharge Voltage: 39.0 V
  • Voltage at Discharge Termination: 30.0 V
  • Nominal Capacity (C/2): 59.1 Ah
  • Standard Discharge: 60 A
  • Max Continuous Charge: 180 A
  • Max Continuous Discharge: 300 A
  • Peak Discharge: 600 A
  • Battery Energy: 2.305 kWh
  • Battery Specific Energy: 205 Wh/kg
  • Dimensions: 10.543” L x 5.495” W x 10.435” H (268 mm L x 140 mm W x 265 mm H)
  • Mass / Weight: 11.25 kg
  • Cooling: Air or Liquid Cooled
  • Cycle Life: 2000 cycles > 80% of Initial, 100% DoD
jedi
Aug 8, 2009
2,813
Nice conversion but curious how they add all that weight to the nose and stay with acceptable CG.
The GP 2330 that is for sale above would make an interesting electric conversion with wing mounted motors and perhaps this battery pack from post # 1,743 above.
Each box has following parameters:
John.Roo
Oct 8, 2013
1,092
=on the base of 202*80 mm 40 kW motor (KV=25, 55, 80.)
on video circa 55 kG thrust.
in CR mode...much more, 4 kG/kW !
This is not that bad result for MP20280 electric motor.
Freerchobby has really interesting range of products.
In my opinion is result of their test also affected by "plate" just behind motor intallation - with mode "aerodynamic" installation could be a bit better.
John.Roo
Oct 8, 2013
1,092
=iff 2x 25 kW in CR FLYGHT mode ?
Well.... I was thinking about test of one 25 kW motor with 2 (or 3) blade folding prop.
1x 25 kW is enough for me ;)
And don´t forget... 1 motor and 1 controller = 2 possible problems.
2 motors and 2 controllers = 4 possible probems :cool:
henryk
Mar 8, 2010
6,517
krakow,poland
=ONLY short time in MAX regime...
I think, the 20280 (40 kW) FRCHobby motor air cooling sysem have better...
=in CRFLIGHT regime cooling is much better (rotating stator and rotor !
"4 possible probems " =yes,but dyvidet by 2 (far from max regimes).
John.Roo
Oct 8, 2013
1,092
I was thinking about 25 kW motor because I need +-15 kW of TakeOff power and arround 5-6 kW for horizontal flight ;)
