Starman's plane
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by Starman, Aug 27, 2009.
  1. Sep 15, 2009 #81
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    High in the Andes Mountains
    I'll make a drawing to save a thousand words :), the D-section is nothing more than a streamlined spar and torsional strength for the wing tip rib. The wire pulling the fabric to the back makes the spar support the fabric.
  2. Sep 15, 2009 #82
    13,157
    5,066
    The battens are often referred to as "ribs". I forgot what they call the small spreader bars at the wingtips (on the newer gliders).
  3. Sep 15, 2009 #83
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    OK, here's the drawing, fast aint I? I think if the wire trailing edge was generally below the bottom of the spar that the blanketing effect should reduce the drag of the spar by a fair amount.
    [​IMG]
  4. Sep 15, 2009 #84
    13,157
    5,066
    I see what you're saying. the D-section holds the end rib in place (without twisting) and the trailing edge wire defines the location of the trailing edge. Are there any ribs in the wing or just battens and the tip rib? Perhaps holes or slots along the span of the D-section would allow you to slip carbon fiber battens in for ribs, then bow them back to the trailing edge wire.
  5. Sep 15, 2009 #85
    Super Moderator Staff Member
    Jul 30, 2005
    13,964
    5,587
    Essentially a Princton Sailwing without the bottom-surface fabric. Search for that term here in the forum, and you'll get some additional information.
  6. Sep 15, 2009 #86
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    OK, I think maybe we've got a plan here. This forum needs a thumbs up emoticon.
  7. Sep 15, 2009 #87
    Jul 30, 2005
    13,964
    5,587
    We usually use this ----> :beer:
    There are some plusses and minuses to the Princeton Sailwing. Start thinking along the lines of ensuring identical rear-wire tension between both wings, and what might happen if you don't achieve that goal, and maintain it in-flight during various maneuvers.
  8. Sep 15, 2009 #88
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    I saw the post about the wire tension and it is important. Possibly use one wire from wingtip to wingtip and let it adjust itself in the middle. That might be a problem though during some maneuvers that create unequal forces on the wings.
    [​IMG]
  9. Sep 15, 2009 #89
    13,157
    5,066
    Why not let the tension vary and hook the control stick to the wire so that it shifts the greater portion of the tension (or, more correctly, slack) from one side to the other?
  10. Sep 15, 2009 #90
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    What an interesting idea. That could possibly serve as aileron action.
    It looks like the Zipper sailwing gets by without battens, but that would be a good fallback scenario because it could be added in later if needed.
  11. Sep 15, 2009 #91
    Jul 30, 2005
    13,964
    5,587
    Off the top of my head, I can't see any reason why it wouldn't work, but then I've done no research at all on sailwings. Might be work a try. I'd do a lot of model tests first, personally. I wonder if you could get enough differential tension in the wires to provide adequate roll control, without allowing any possibility of too much slack appearing in the 'loose' side. I could see "luffing" being a problem in that scenario.
  12. Sep 15, 2009 #92
    13,157
    5,066
    "Luffing"??? :confused:
  13. Sep 15, 2009 #93
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    Luffing is a sailboat term which describes the sail flapping or rippling due to improper wind direction/sail tension.
    ______________
    Just a reminder as to where this design could be eventually heading, possibly something for my brother who is a retired F16 pilot.
    With something like a V10 or four rotor wankel for power.
    This is the main reason that the spar sweep needs to be adaptable. In a case like this the horizontal tail attach points act as torsion connections for the wing.
  14. Sep 15, 2009 #94
    Jul 30, 2005
    13,964
    5,587
    Why not just go there in the first place, perhaps with a little less leading edge sweep and a bit more area? Those wings would be a snap to build in foam and glass. Keep the weight and wing-loading down and this isn't much more than a pusher Dyke Delta. A bigger, more powerful motor and a higher wing loading could be used for your brother. With just a little rework, the engine could be on the CG, making it much easier to accomodate such changes.
    All the added complexity of multiple wing sets, tail sets, and varying control systems - and accomodating those in the original fuselage design - seems like a needless complication. By the time you'd build any of those, you could have sufficient pilot training and experience to handle a lightly-loaded delta like this. There really isn't any 'shortcut' to building an airplane. No matter what you eventually do, the design and build process is going to take a couple of years, absolute minimum.
    You can do a lot of training and flying in a couple of years.
  15. Sep 15, 2009 #95
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    Well that's always a possibility. Luckily I don't need to make that choice till I'm well along with the fuselage. In a case like this most of the center spar strength would be wasted, I guess, but I can live with that. At least it would be easy to figure out where to store the landing gear.
  16. Sep 15, 2009 #96
    Jul 30, 2005
    13,964
    5,587
    Well, you know that I disagree with you on that score, but there's no point in repeating the discussion. We'll simply have to agree to disagree about the philosophy of building before the design is complete.
  17. Sep 15, 2009 #97
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    That's fine, I can't see much that would need to be changed with the fuselage other than the spar center section being overbuilt for a small delta, it would be better for the bigger delta that you described. Of course when I make the fiberglass rear body panels (if I use fabric first) I will need to add some stringers or attach points for them.
    Cooling inlets would need to be varied according to potential speed. What else?
    I realize that due to the adaptability that it won't be optimized for most cases, but it should be pretty close.
  18. Sep 15, 2009 #98
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    Topaz, I see you added more to your earlier post. You're starting to talk me into it, or out of it, depending on how you look at it :)
    I DO like deltas a lot.
  19. Sep 15, 2009 #99
    13,157
    5,066
    Just for the heck of it, you should look up the Dyke Delta and read a little about it. From the photos I've seen, it looks like the entire airframe structure (fuselage, rudder, wing spars, wing ribs) is made up of welded steel truss work, then covered. The only think I've read that might be considered a shortfall is that approaches should be made flat with power carried.
  20. Sep 15, 2009 #100
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    I've studied the Dyke Delta quite a lot, it uses fiberglass panels laid up on a flat smooth surface, I forgot how he attaches them, I want to say pop rivets but fiberglass doesn't like that too much. I've read that technically the Dyke is not a delta but a highly tapered flying wing with slight sweep.
    I better get to work now.
