Starman's plane
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by Starman, Aug 27, 2009.
  1. Sep 20, 2009 #121
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    High in the Andes Mountains
    OK, you talked me into it. I'm making a delta pusher, no more analysis paralysis. Wish me luck, no wait, I'm not supposed to say that, I don't need luck :) Drawings coming soon.
  2. Sep 21, 2009 #122
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    This isn't one of the ten second computer sketches. This shows the delta planform, based loosely on the Rohr delta. It has 200 sq ft of wing area, designated by the red triangle, which is what was used to geometrically calculate the MAC and the CG. The wing loading is around seven pounds per square foot as long as it's not stuffed with fuel for a long trip, and will give a lower landing speed than the Rohr delta and probably the C172 also. This shows the CG at the 25% point, if it needs to be at the 17% it will be more forward, closer to the one in my previous posted drawing. The elevons and trim tabs have been excluded from the area calculations and the MAC calculation in order to provide a good safety margin. The wing span is a little more than 26 feet. The center section is six feet wide.
    In the side view the red airfoil shapes show the contours at one foot and two feet from the centerline, showing that the fuselage is airfoil shaped and is an efficient lifting body. The green airfoil shape is the wing root, and the blue outline shows the wing folded in the same manner that the Grumman cats do, for towing on the road.
    The things that look like inboard control surfaces on the top view are the trim tabs, which provide the reflex to the wing, and it's an adjustable reflex.
    The center section airfoil/fuselage has a sharp leading edge so that it will stall first and tend to drop the nose to prevent too much pitchup at high AOA and high G situations.
  3. Sep 21, 2009 #123
    addaon
    addaon
    addaon
    Feb 24, 2008
    1,686
    101
    San Jose, CA
    Providing reflex primarily towards the root of the wing does put you at risk of tip stalls. You'll want to reflex your elevons at least as much, and use the inboard sections for just a little trim (if at all). Personally, I'd go for full-span elevons and use either conventional trim tabs or spring trim.
  4. Sep 21, 2009 #124
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    Thanks, will do.
  5. Sep 21, 2009 #125
    flyvulcan
    flyvulcan
    flyvulcan
    Aug 6, 2007
    525
    311
    Adelaide, Australia
    Hi Starman,
    There was a single seat derivative of the Dyke Delta produced in the '80s I think it was called the Delta Stingray. It was designed and built by Mr. Lowell Borchers. It used a single piston engine mounted in the nose and had a single vertical stabiliser. However, the delta planform is akin to the drawing that you have made.
    I spoke with Mr. Borchers a few months ago about his aircraft and he indicated that it flew very nicely (after some experimentation which included adding a very small horizontal stab about 3/4 the way up his vertical stab).
    I dont believe that he has any of the design paperwork/drawings for his aircraft any more but his experiences with a homebuilt delta may assist you. He has donated his aircraft to his local museum where it is available to be viewed. He was very pleasant to talk to and may be able to give you some useful tips.
    All the best with your project.
    Flyvulcan
  6. Sep 21, 2009 #126
    addaon
    addaon
    addaon
    Feb 24, 2008
    1,686
    101
    San Jose, CA
    Another concern with deltas, and one of the reasons I dropped my ideas for one, is where do you put the **** prop? In front (Dyke style) it looks a bit silly, in my opinion; but aft, as you have it drawn, you have major ground clearance issues. Keep in mind that deltas will typically land at significantly higher angles of attack (at least potentially; you might land fast 90% of the time, but sometimes you'll want to land short) than "normal" designs, so you'd be looking for about 9" prop clearance at 30° AoA. And that's not even taking into account extra clearance to prevent the tires from throwing crap into the prop disk...
  7. Sep 21, 2009 #127
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    Hi Flyvulcan, where is this plane on display and how would I go about contacting him? I Goggled it and didn't see any pictures or much in the way of specs either. I found where it said it has a speed of 85mph and uses an 0-200 engine. I'm thinking my plane might get by on 100hp but it might be marginal. I'm designing it assuming I may someday have as much as 500 or more hp, maybe way more for short bursts.
  8. Sep 21, 2009 #128
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    I'm sorry to hear about that, too bad I wasn't here to be an idea man for you. :) I've thought about this and have a couple of solutions up my sleeve. One is to put small training wheels on the bottom of the vertical stabilizers. The other is to put Quickie style main wheels near the wing tips (if it was more like a flying wing, but then you can't fold the wings Grumman style), or put the main wheels on the vertical tails. This will require a very long front gear so that the plane is pre rotated. In the pre rotated position the front gear would be about 8 ft long, which could look cool, and it would have to be a kneeling design like the VariEze in order to be able to get in and out, or a rope ladder :), with a strong pneumatic or hydraulic extension mechanism in order to extend while I'm a settin' in it. So there would be one awkward landing gear to retract instead of three 'normal' ones, a fair trade.
    In order to keep junk out of the prop the main wheels will need to have a wide stance when extended, and maybe put a deflector on the front wheel.
  9. Sep 21, 2009 #129
    13,171
    5,083
    I believe the Dyke Delta gear is designed to place the wing at a positive angle of attack while sitting on the ground for that very reason.
    Some VariEze, LongEze/Cozy builders put in a hydraulic nosegear extender so they can board on the groud with the nose low and then raise the nose once they are in. As for the Dyke Delta, I think boarding access may be from the trailing edge and up a wing walk (would require shutting down the engine for safe boarding).
  10. Sep 21, 2009 #130
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    I got the idea about the 'kneeling' nose gear from those variEze builders that use the hydraulic nose gear extension while they are in the plane. I think that the Dyke Delta users board over the side, needing a step ladder, except I saw one that had the top of the strake fold out and down and it had a built in step or two. I looked for pictures of it but couldn't find it.
    Following is the two possibilities I am considering. The top pic shows conventional trike gear with small safety wheels on the tails. The wing is at one degree of incidence (fuselage has more) and the max rotation on this, assuming the airplane will rise on the long travel gear as it rotates, is 20 degrees, for a total AOA of 21 degrees for takeoff. The lower drawing shows the main gear in the tails with a single retracting gear at the front. The front landing gear on this one is nearly seven feet long and in the raised position the bottom of the cockpit is about six feet in the air and it still has less rotation than the upper one. It seems either one would need to be kneeling because even on the top one the gear is four feet high.
    Trade offs for decision on this is the lower one would be less overall labor to build but the upper one looks sexier and more 'threatening' while taxiing. The upper one normally has the prop far from the ground while the lower one has the prop always near the ground, but the lower one has the wheels behind the prop so there is less chance of them throwing things into the prop. I've read that props can suck things off the ground, that they don't need to be thrown by the tires.
    So far I'm leaning towards the upper one, which could get by with fixed gear at first.
  11. Sep 21, 2009 #131
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    I'm thinking of using hydraulic or pneumatic gear operation. With pneumatic I can have a tiny air compressor filling a small high pressure tank or a big low pressure tank, and the air pressure could be made to act like a spring.
  12. Sep 21, 2009 #132
    Super Moderator Staff Member
    Jul 30, 2005
    13,964
    5,588
    Three things to consider:
    1) View over the nose while taxiing the second option. Or lack thereof.
    2) The prop will, indeed, suck sticks, rocks, dirt, and just about anything else up off the ground even if it's a good foot or so above the dirt. I've seen our towplanes at the soaring club creating little tornadoes of dirt and grit even at fairly low power settings, and they're taildraggers.
    3) The nosewheel will throw up rocks, to, so with a pusher such as this one (or any where the lower prop arc is unprotected), you're going to be limited to paved runways at all times, for either of your configurations. That may not be a problem for you, but it should be noted.
  13. Sep 22, 2009 #133
    BDD
    BDD
    BDD
    Apr 2, 2005
    388
    3
    WI
    Having an extra "tailwheel" on the rudders would help protect the prop from hitting the ground at rotation but it could also damage the rudder and the wing it's attached to when that contact occurs.
    The alternative would be engine and prop at the front and no tail extending near the ground.
  14. Sep 22, 2009 #134
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    I had a solution for that when I came up with that idea, but when I read your post I momentarily forgot about it :) I was thinking of using pneumatic operation for the gear, which can also provide a spring effect, and while taxiing I could let some air out of the lift cylinder in order to drop the nose part way to make the plane level or nose down, only raising it for takeoff, but it still seems unacceptable to block the forward view during takeoff. Also, changing the angle of the gear leg will change the rake and caster of the wheel which would make it more interesting to design. Choppers get away with a lot of rake so it could still work.
    I'm guessing that's more a function of the prop blast being angled downwards in a taildragger? In the conventional gear version of this delta the prop is about three feet off the ground and angled upwards.
    I hadn't thought about that limitation but if all the other pusher drivers live with it so can I. So many runways are paved that I don't think I will miss using dirt strips.
  15. Sep 22, 2009 #135
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    That's true, but as I showed it, and plan it, the tailwheels will be on strong springs which will soak up pretty good whack, the tail structure will be strong and isn't connected directly to the wing, I don't make something if it isn't strong, and the bottom of the rudder is somewhat removed from the bottom of the tail, so even if there was a hard enough impact to damage the tail it might not get as far as the rudder. on top of all that, I'm not expecting to be rotating that hard or far.
    During normal landings low aspect ratio planes tend to flatten out and lessen pitch when they get into ground effect, so this will lessen the likelyhood of hitting the tailwheels during landings, but that's just what they are there for anyway, just in case, so they will be built for it. There's always the possibility that some landing somewhere will be hard enough to damage the tail structure, so it will need to have a weaker 'fail' point built in so the damage doesn't get as far as the rear wing connection, which on the tube which holds the tail.
    In a hard enough landing the question becomes: Which is the least expensive to damage, the vertical tails or the prop? If the landing is hard enough it could damage both. One my plane I don't think a prop strike would damage the engine because there's going to be a floppy sloppy torsion bar connecting the prop to the engine and I'll be using a car engine. Car engines have crankshafts orders of magnitude stronger than the old antique opposed air cooled airplane engines. Since they are air cooled and the cylinders are so far appart the crankshafts are very big and long, yet in order to be light they are very skinny and wimpy. Just seeing one of those crankshafts lying on a work bench makes you want to run for cover :)
    On the other hand, a two rotor wankel has a crankshaft about a million times stronger, or something.
  16. Sep 22, 2009 #136
    Joe Fisher
    Joe Fisher
    Joe Fisher
    Feb 11, 2007
    1,379
    376
    Some of the R/C deltas put the engine in the middle with the prop running in a slot and between the main gear.
  17. Sep 22, 2009 #137
    Jul 30, 2005
    13,964
    5,588
    Yeah, you'd think, except that the little whirlwinds are fixed in place relative to the prop, in the plane of the prop disk. Basically it looks like it's hanging down from the prop tips to the ground.
  18. Sep 22, 2009 #138
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    Cool! It's nice to have a little mind blower in the morning. It must be due to the reverse flow, or backwash, around the prop when it is stationary or moving slowly. What is the technical term for that? Tip vortex?
  19. Sep 22, 2009 #139
    13,171
    5,083
    I think you can probably be partially attributed to the tip vortices that roll off of the prop tips and induces a tornado-like circulation.
  20. Sep 22, 2009 #140
    BDD
    BDD
    BDD
    Apr 2, 2005
    388
    3
    WI
    This would be happening at all times and even more so at high rpm's. as at take-off.
