Yeah, that is scary. I will stick with 40 year old technology.
No. Not my job to educate you. The internet has everything you need. Just go looking for it. When I was young, the only sources of information we had was a few magazines and whatever the local library happened to have, which was pretty much nothing.Therefore, we need a specific analysis of specific problems.
we start from beginning,
Please point out the fatal flaw of this scheme
Cblink & Thjakits:
Section1:
The number of blades is a cheap and efficient way to solve the lift balance of the rotor,
Even when the number of blades is large enough, there is no core problem of rotor lift balance, which is the core of the rotor system. ... the reason for this historical core problem is that the rotor has too few blades.
C. So, I tried my best to increase the number of blades. I must be the opposite of what you think of as great rotor history.
D. If you guys can prove my point wrong, I'll retract and review my design right away.
Although you've obviously gone in circles and didn't answer my most central question, I don't want to simply dismiss you.NO ... NO .... NO .... and .... NO
A helicopter will fly just fine with just one blade (it has been done)
But it requires a heavy counterweight to balance everything
Might as well just add another blade instead of the counterweight (and that is what they do)
Remember that a spinning rotor acts like a round disc in the air .... more blades or less blades do not change that.
3 or more blades do have many advantages .... shorter blades can be used and they make less noise ... etc
Study the 1968 Bell 212 .... two huge blades .... about 3 feet wide .... WOP WOP WOP sound (Viet Nam era) ... max speed about 140 mph
Modern Bell 412 is pretty much the same machine with 4 blades and other updates .... max speed about 160 mph .... not much faster but quieter..
dong090909 .... your problem is you dont know what you dont know .
Spend more time studying helicopters
Then start inventing.
Now, let me answer your question.NO ... NO .... NO .... and .... NO
Perhaps, now is the time to embody your philosophy: put aside the tediousness and use the most direct and simple method.Dong09,
I am too tired at this time to answer - again - your various and some of these very erroneous assumptions - I'll see if I have some time and patience tomorrow...
At this stage I only can assume (....and actually hope) that most of what comes through in your posts is really just a difficult translator!!
Your posts seem to indicate, that you have absolutely NO understanding - not even basics - of powered rotor flight.
You seem not to listen at all, what accomplished professionals are suggesting to you!
Most of your arguments make no sense - you try to correct non-existing problems by inventing REAL problems!!
Just a very quick observation:
You think you can solve dissymmetry of lift and the required and proven solutions just by increasing the number of rotor-blades!! My friend, a helicopter rotor is NOT a fan!! To be able to control a powered rotor you need to really study how a rotor works! It doesn't matter if you use a 2-blade rotor or a 8-blade rotor - still, every blade goes through the same motion on every revolution of the rotor!! You cannot do away with rotor control just by increasing the number of blades and slowing the overall possible forward speed - it does not work like that!
Your fantasy speed of 60 km/h will not work as a transition speed - you are not in airplane territory there - you are in slow ultra-light territory!!
[Actually - you COULD make it work at 60 - with FANS!! NO rotors, just fans! You will need a LOT of power and control surfaces for the fan flow - THAT could possibly work if you are careful with the design - it will be very inefficient compared to a rotor, but if you limit your vertical powered flight regime to that stated by you - you very likely would be successful with a multiple ducted fan design for the vertical flight part! Look up the "Moeller Flying Car" and ....about every Electric Vertical Take-off and Landing Vehicle dreamed up so far!]
Back to REAL rotors:
You CANNOT increase your blade number into infinity and pretend a solid disc - saucer - UFO will still work like a rotor system!! You seem to have NO understanding of aerodynamic flow over an airfoil/rotor - eventually you will have flow from a rotor influence the flow of the next rotor ( and usually in a bad way!).
When you go infinity/solid - there is no more flow over rotor blades - there is only flow over a solid disc - which has absolutely NOTHING to do with aerodynamics over a rotor!
For a powered rotor to work you need to control it! A light gyroplane rotor is NOT a powered rotor - it is a fixed pitch windmill - it is at a fixed speed - a permanently autorotating system - most are a crude - essentially - weight-shift affair! A more sophisticated system would still require a fully controllable rotor (like the Air&Space 18A).
According to your plans you have TWO fully powered rotors!!
Before you even think about diving into the above mentioned MECHANICS book about helicopters - learn how a conventional helicopter works - get yourself ANY book that has these words in the title: "Principals of rotor flight" or "Principals of helicopter flight" here is one example: Amazon.com
When you have actually read, learned and understood the presently in production an working fairly flawless classic/traditional rotor system of presently perfectly working helicopters - THEN come back and start discussing any plans you still might have to revolutionize powered rotor flight!!
What you are presently arguing is close to nonsense - your arguments that will lead Sikorsky (and presumably every other rotorcraft powerhouse) into bankruptcy shortly have absolutely no reason or substance in the rotorcraft industry. Learn what is possible with the present rotor systems before you argue their flaws ...and worse - invent problems that do not exist and only can be remedied by your "solutions" that are actually worse problems than you seem to see!!
Again - I hope that most misunderstandings here are a translation problem and not your actual arguments!!
Do yourself a favor and try to study up actual helicopter flight principals and understand them - that alone will do away with most of your misconceptions and as a result will severely change your design!!
If you cannot access the above mentioned book or similar:
I don't know if you can access these sites in China but here are a few just to get you started!
How Helicopters Work
Believe it or not, the marvel we know as the helicopter began as a Chinese top consisting of a shaft — a stick — adorned with feathers on one end.science.howstuffworks.com
How does a helicopter work? | Who invented helicopters?
A simple introduction to how helicopters stay airborne and steer.www.explainthatstuff.com
How do Helicopters Fly? • Barossa Helicopters -
barossahelicopters.com.au
here a search - query on youtube:
As I said - I have NO idea if you are able to access these sites from China, if you can - search for any basic term of a helicopter and you will find something to study about it!
I am pretty sure China has it's own version of educational internet. Principals of helicopter flight are no secret.
You should be able to access ALL the information you need to learn the basic things about helicopter flight!
Learn and understand what is working today!! Only then you can try to improve or revolutionize Rotor-flight!!
The problems you state are NOT REAL!!
I hope you understand this post after translating it!
Dong09 - DO as was suggested to you by various people above (incl. myself) - STUDY what was suggested and THEN come back and discuss again...
Just repeating your misguided assumptions and dismissing professional suggestions will thin your audience to zero in a very short time....
We all love to discuss aviation on here and the more extreme it gets the more exciting for all!
We all love to help out and introduce new people that are enthusiastic about aviation!
We all share experience willingly and free of charge!
WE do NOT hang around very long for useless arguments....
Good luck Dong09!!
thjakits
dong090909
From the beginning you have nothing good to say about Sikorsky
You pretend to be better than them with your cardboard tube , sticks , and glue gun..
Here is what Sikorsky was doing in 1948
Speed record 129.6 mph
First helicopter to perform a loop.
You were not even born yet
Your father was not even born yet.
As a tilt-rotor pilot, as has @thjakits has suggested, you are aiming to solve what you perceive as a critical problem. This is great! However, you do not understand the fundamental principles, as you are presenting a solution that makes no sense to any of us; as it creates problems that have been long-since solved.I have countless examples to sing Sikorsky, but I don't have the time. Because, I am now really improving on the flaws of this great company.
I don't need to cover up hypocritically.
That book covers all the principles of flight of the various helicopter configurations, then it gets into the details of the systems. It's much more than just how to maintain a helicopter. Mechanics are expected to know all of it, and they usually know a lot more about the machine and how it works than the pilot does.Before you even think about diving into the above mentioned MECHANICS book about helicopters - learn how a conventional helicopter works - get yourself ANY book that has these words in the title: "Principals of rotor flight" or "Principals of helicopter flight" here is one example: Amazon.com
