Those full-size Yaks were not replicas, they were genuine Yaks from the the Yak factory, new-built. There is at least one based here in NZ too.
Item | Full | 75% | 65% | 55% | 60% | Plan |
Span (ft) | 30.8 | 23.1 | 20.0 | 16.9 | 18.5 | 17.63 “ |
Chord (in) | 57.7 | 43.3 | 37.6 | 31.8 | 34.7 | 2.75 “ |
Length (ft) | 27.7 | 20.7 | 18.0 | 13.6 | 16.6 | 15.8 “ |
Width (in) | 30.0 | 22.5 | 19.5 | 16.5 | 18.0 | 1.42 |
*Add for min | - | 1.5 | 4.5 | 7.5 | 6 | |
Height (in) | 58.0 | 43.5 | 37.7 | 31.9 | 34.8 | 2.76 |
*Add for min | - | - | 2.3 | 8.1 | 5.2 | |
Area (ft2) | 296 | 166 | 125 | 89 | 107 | 0.67 |
Gross weight (lb) | 4675 | 1320 | 1144 | 970 | 1056 | |
Wing Loading (lb/ft2)(oz/ft2) | 15.7 253 | 8 128 | 9.1 146 | 10.8 146 | 9.9 158 | |
Power Loading (lb/HP) | 5.5 | 13.2(100 HP) 8.8 (150 HP) | “ | “ | “ | |
Vm (mph) | 245 | 205 | 198 | 181 | 188 | |
Vc (mph) | 172 | 144 | 139 | 127 | 132 | |
Vs (mph) | 59 | 42 | 48 | 49 | 46 | |
Multi-engined replicas are rare.Sweet!
A guy near Montreal built a reduced-scale replica of a Grumman Bearcat, during the 1970s. The engine was only around 100 horsepower (VW or Continental????).Something a little faster?
F8F carrier based interceptor.
Rotec radial engine.
All aluminum structure.
This is a bit larger aircraft.
If we can have imaginary engines then...
Double Row Rotec radial 18 cylinder?
This one could also morph into a
two seat T28?
I've got idea's floating around in my brain, but can't decide. And I don't want to yet. I wanna do a warbird build when I can do it right and fully. Other things, you can cut corners, or changes something, but when I'm gonna do my warbird build, I wanna be able to go all out, and right now, that just isn't in the cards. The ideas I have are scale versions of
Fokker DR.I
Grumman F6F
Grumman F8F
Bell P-63
Grumman F3F
Boeing P-26
Hawker Sea Fury
Supermarine Spiteful
Vought F4U
One day I'll sort it all out and figure out which one I like best...
I remember that Bf-109 replica, the gear collapsed after a landing. The builder got several enquiries regarding building plans or kits, but he decided that this particular plane does not lend itself well for a scaled down replica.
The gear is notoriously bad, and the cockpit is quite cramped even in the full-size version!
How about a Fiat CR 32, based on that Czech replica.? Or a CR 42 around a Rotec radial?An interesting aircraft I have looked at a bit is the Avia B-534. It's a prewar biplane Czech fighter and one subscale version has been built in Europe.
Here's a Youtube link:
I have a set of giant scale RC plans for it and combined with an inline engine such as a Viking or AeroMomentum I think it would be a nice project.
Here's a comparison study I did a while ago:
Avia B-534 Homebuilt Study
Item Full 75% 65% 55% 60% PlanSpan (ft) 30.8 23.1 20.0 16.9 18.5 17.63 “Chord (in) 57.7 43.3 37.6 31.8 34.7 2.75 “Length (ft) 27.7 20.7 18.0 13.6 16.6 15.8 “Width (in) 30.0 22.5 19.5 16.5 18.0 1.42*Add for min - 1.5 4.5 7.5 6 Height (in) 58.0 43.5 37.7 31.9 34.8 2.76*Add for min - - 2.3 8.1 5.2 Area (ft2) 296 166 125 89 107 0.67Gross weight (lb) 4675 1320 1144 970 1056 Wing Loading (lb/ft2)(oz/ft2) 15.7
253 8
128 9.1
146 10.8
146 9.9
158 Power Loading (lb/HP) 5.5 13.2(100 HP)
8.8 (150 HP)
“ Vm (mph) 245 205 198 181 188 Vc (mph) 172 144 139 127 132 Vs (mph) 59 42 48 49 46
Sport Aircraft: 1320 lbs max, Vs ≤ 51 mph Vs = 3.7 (wing loading (oz/ft2))1/2
*Min width = 24”, Min height = 40”
I think that one was a Jurca MJ90 100% scale. Powered by a Ranger engine it was not built well, I talked to an IA who inspected it, he told the builder that it was unsafe to fly. That was before the gear collapsed. It was offer to a museum which turned it down as there was a large lien from the airfield and the airframe was in bad shape from sitting.I remember that Bf-109 replica, the gear collapsed after a landing. The builder got several enquiries regarding building plans or kits, but he decided that this particular plane does not lend itself well for a scaled down replica.
