Paulownia Elongata?
J.L. Frusha
Feb 17, 2006
1,264
Luling, Texas
A light, machinable straight, coarse-grained fast-growing hardwood, supposedly known as "The Aluminum of Hardwoods". Supposedly bug and water resistant, Sounds almost too good to be true...
Common Name(s): Paulownia, Royal Paulownia, Princess Tree, Kiri
Scientific Name: Paulownia tomentosa
Distribution: Native to eastern Asia; also planted in eastern North America
Tree Size: 30-65 ft (10-20 m) tall, 2-4 ft (.6-1.2 m) trunk diameter
Average Dried Weight: 18 lbs/ft3 (280 kg/m3) (Aluminum: 168.48 lbs/ft3)
Specific Gravity (Basic, 12% MC): .25, .28 (Aluminum 2.7)
Janka Hardness: 300 lbf (1,330 N)
Modulus of Rupture: 5,480 lbf/in2 (37.8 MPa)
Elastic Modulus: 635,000 lbf/in2 (4.38 GPa)
Crushing Strength: 3,010 lbf/in2 (20.7 MPa)
Shrinkage: Radial: 2.4%, Tangential: 3.9%, Volumetric: 6.4%, T/R Ratio: 1.6
________________________________________________________________________________
Sitka spruce – physical properties
Density (kg/m3)Green347
Air dry387
Specific gravity (12% m.c.)Standard0.35
Hardness (N)Side2200
End3090
MOE (Mpa)Green9450
Air dry11200
MOR (Mpa)Green37.4
Air dry69.8
Compression parallel (Mpa)Air dry37.4
Compression perpendicular (Mpa)Air dry4.10
Shear (Mpa)Air dry6.78
Cleavage (N/mm width)Air dry38.0
Shrinkage
OD = oven dry
air = air dry 12%
Radial (OD)4.6%
Tangential (OD)7.8%
Volumetric (OD)11.7%
Volumetric (air)6.0%
Tang / rad ratio1.7
