Pantograph
Discussion in 'Composites' started by Jstorrshall, Dec 28, 2018.
  1. Dec 28, 2018 #1
    Jstorrshall
    Jstorrshall
    Jstorrshall
    Sep 3, 2013
    20
    3
    Melfa, VA USA
    So, has anyone ever used a pantograph for hot-wire cutting? It would seem an obvious trick to try, in a down-scaling mode.
  2. Dec 28, 2018 #2
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,233
    2,854
    Las Cruces, NM
    With a pin in a slot on template? ....or?
    1221__35103.1506029041.451.416.jpg Like a router duplicator except with a 2D template on one end and 3D (hotwire) on the other.
  3. Dec 28, 2018 #3
    Oct 19, 2003
    5,627
    2,866
    You would likely need two, one for each end. Then talking points on both ends too. Sounds like complicated for no advantage to me... I too am sure someone has done it too...
    Topaz likes this.
  4. Jan 1, 2019 #4
    Jstorrshall
    Jstorrshall
    Jstorrshall
    Sep 3, 2013
    20
    3
    Melfa, VA USA
    Shouldn't be all that much trouble to make a coupled pair so that you don't need two people. Alternatively use one (like the router version) to move the foam block around on a platform/vertical wire cutter.
  5. Jan 2, 2019 #5
    Markproa
    Markproa
    Markproa
    Feb 9, 2017
    76
    30
    Bellingen, NSW. Australia.
    Simple if both end profiles are the same, difficult if not, like a tapering wing.
  6. Jan 2, 2019 #6
    2,772
    1,534
    I guess for cutting foam this “pantograph” would take your input at one end of the wire and duplicate it on the other? I’m trying to picture exactly how such a rig would work but it might be a neat way to cut cores solo, especially if the rig could be tweaked to make one end work at a reduced scale for tapered planforms. I’m not sure it would be able to handle washout though, and you’d be sunk if you wanted the airfoil to change from root to tip.
  7. Jan 2, 2019 #7
    Oct 19, 2003
    5,627
    2,866
    The thing everybody misses about a pantograph or similar setup is that the precision of the device to do as good a job as two humans with templates is actually pretty high. For a single pantograph to follow cleanly, you must have no slop in the bearings at all of the joints and drag in those same bearings must be low. Then to drive a second tracer, the second tracer will lag behind the first one in proportion to the forces and the stiffness of the linkage between them. Yeah, it won't just lag, the lag will be bigger when forces are high and smaller when forces drop, like when you pause at a corner.
    So it would have to be stiff and have zero slop and little friction. Begins to sound pretty massive to me.
    Then let's consider the rest of the problem. Most wings have a little washout built into them, they taper, and sometimes the foil at one end is different from the other end. Also, any spar cap troughs start out deep at the root end and taper to practically nothing at the tip. You can taper the part with a pantograph (by gearing), and you might be able to twist it (by setup), but you play merry hell using different foils and big differences in trough depth with such an arrangement.
    The folks who have taken the human element out of hot wiring and made fancy parts have driven the frame for the hot wire with 2D CNC on each end. This can make for equivalent or better quality than the typical homebuilder's scheme:
    The frame for the wire can be much stiffer because the weight matters little to machine tool;
    The wire can be kept at constant temperature and constant low speed throughout the cut;
    The profiles are independent of each other - they can be programmed for each end;
    The entire shape can be run as a single long piece of foam instead of doing several short forms and putting them together later.
    As for me, I kind of like having simple inexpensive tools, getting a friend or two over for a session, followed by food and beers.
  8. Jan 2, 2019 #8
    Norman
    Norman
    Norman
    Nov 29, 2003
    2,877
    902
    Grand Junction, Colorado
    Are you sure about that? I've never cut blanks more than 3' so I'm not sure but I've been told that wire sag will cause noticeable distortion at greater than 4'. Even on small parts of only 1" I can see the wire bend a few degrees as it enters the blank and have to wonder how far the center of the wire is lagging behind the ends on long parts. Also when the wire exits the part the ends come out first showing that even on short parts the wire is "sagging" (sagging is in quotations because the so called "sag" is horizontal indicating friction lag rather than gravity sag). The first "long" cut I ever made was using the "two guys with station marks on the templates" method and I found it awkward. You just can't maintain constant speed and the result is often a washboard (by my standards ~ 0.02 wave height). After a couple of what I considered inadequate results we built a drop bar that clamps onto the edge of the building table and got pretty consistent results. A drop bar is a much simpler device than a pair of pantographs and easily cuts tapered, twisted parts with different profiles at the ends.
  9. Jan 2, 2019 #9
    Oct 19, 2003
    5,627
    2,866
    I would never try to do a hand guided wire cut more than four feet for exactly the reasons cited by Norman, but if you have CNC drives at each end and closed loop control of wire temperature, you can tension the wire and drive it slowly enough to have excellent accuracy and very little lag.
    Here is one thread where a guy does 10' cuts. http://www.homebuiltairplanes.com/forums/showthread.php?t=1429&highlight=wire+cut+core
    There was another thread where full wing cores were cut this way, but I can not find it right now - IIRC they drove from Germany to Poland to pick up the new cores...
  10. Jan 4, 2019 #10
    Jstorrshall
    Jstorrshall
    Jstorrshall
    Sep 3, 2013
    20
    3
    Melfa, VA USA
    Can you post a picture please?
  11. Jan 4, 2019 #11
    Norman
    Norman
    Norman
    Nov 29, 2003
    2,877
    902
    How about a video:
    [video]https://www.youtu.be/zlWqHXpSttk[/video]
    Hope that worked, had to type it in, cut & paste isn't working on this stpid phone.
  12. Jan 4, 2019 #12
    Norman
    Norman
    Norman
    Nov 29, 2003
    2,877
    902
    How about a video:
    [video=youtube_share;zlWqHXpSttk]https://youtu.be/zlWqHXpSttk[/video]
    wsimpso1 likes this.
  13. Jan 4, 2019 #13
    lr27
    lr27
    lr27
    Nov 3, 2007
    3,216
    463
    If you can control wire speed well enough, you can prevent the wire from touching foam at all. Then gravity will be the only cause of sag. Cores cut this way are very nice. Anker at rcgroups.com discusses this.
  14. Jan 6, 2019 #14
    Jstorrshall
    Jstorrshall
    Jstorrshall
    Sep 3, 2013
    20
    3
    Melfa, VA USA
    Norm, Great, thanks!
