stanislavz
Now, i am actively reading forum from back to now, seeing some invaluable info / trying to gain more knowledge. 99 % of mine already asked question was answered before on HBA. But some question - was not. Or not to level, which i would like.
1. Laminar/turbulent airfoils. Fabric wing should be used with turbulent airfoil, laminar should be used only with rigid skin wings and not used when you have to many insects/ rain / debris etc. And laminar airfoil have to be build with high geometric accuracy.
But - can it be explained in number ? ie - to achieve laminar flow, nose section should be build with 0.1% geometric accuracy, and surface finished to high gloss ? Deflections due to wing load less than 0.03% ? And - where all have to be very accure (ie nose), and where all should be just ok (ie bottom)
2. Rutan / Long ez etc wing connecting using "bolts"
I can understand "metal thinking" in some composite builds, using metal like connector to connect wing.
Most factory builds are using "central box / glider box" to connect wings. Which looks to be lighter and stronger (Closed shape/vs open shape). Ct wing mount is below :
And the question is - do Rutan way was chosen for easier life of one off builders ?
3. Long ez have fuel in tanks placed in central wing station. But wings are build as foam cored using PS foam..
Which according to forum knowledge - have to be spaced as far as possible. Is it ok solution ?
Thanks !
Thanks !
