JayWelchy
Well I am at that point .. need to take a step back. I have been practicing my new OA setup for the last few days .. got a total of around 6 hrs OA time, not much at all. Dont expect to pick it up quickly, but at this point I dont have a clue and its wearing on me bigtime.
So far, using 4psi on both O an A, a #1 tip and the "neutral" flame, I just cant find a happy medium. On thick steel ( 1/8" or so, #5 tip) I can sorta get a puddle sorta around where I think it should be. Adding filler wire is a challenge unto itself .. seems I want to put it in the flame, or I just miss the puddle and end up soldering the wire to some spot away from where I want it. No biggie, as that is just coordination which I will get. On the thick stuff, I can see the puddle, and slightly manipulate it. But barely. And I am barbaqueing the surrounding metal...I think. Read charcoal below.
The next issue, again inexperience bigtime, is that as I am trying to keep heat on or around a puddle, everywhere around the puddle is sizzling away .. like its boiling or just plain burning the metal all around. Not burning through, just the surface. Horribly worse on .035 Chromo. It looks really gnarly when it cools. Oh, and its like a milli-second after I add filler that it Pops! ... even if the torch is far away from the work. Bummed.
And further, when I am done making my mess, the finished steel, looks like charcoal... on the outside AND on the inside (tubing). Its like I am getting it all too hot?? Burning the "skin" layer?
Man, I just dont know, but it has me in the dumps a bit as I have this gorgeous piece of artwork of a fuselage that I DO NOT want to destroy with my failed attempts. Funny, I am pretty stable and secure about my abilities to learn, but I am a bit concerned at this point :-\
I can Mig weld, I understand the process and the temps. Ive read more info on OA and watched lots O' vids.
Let me say I knew it would be a slow learning process .. but I just cant grasp that I cant figure out what I am doing wrong. Might take a break from all of this for awhile till I can move forward.
Anyhoo, any comments good or bad are all I am hoping for from this thread.
Jason
Jason
