Maybe the next best Ultralight Engine!
Armilite
Sep 5, 2011
3,750
AMES, IA USA
Rated 33kw = 44.25373hp at 8750rpms if it can be converted easy. Maybe run at a little lower rpms. Use's Ceramic Apex Seals. Don't know, if it use's the High Temp O-Rings the Mazda guys use. But this looks like and awesome small motor. Max rpms is 11,000rpms!
Follow us on FACEBOOK and TWITTER
Type : 4-stroke single rotor rotary engineDual Inlet with vacuum controlOnboard starter
Power : 33 kW at 8750 rpmFloat carburettor with air filterExternal starter
Weight : ca. 17 kgClutch with 11T sprocket and coverCeramic apex seals
Torque : 39 Nm at 7500 rpm3-piece exhaust with manifold and springs10T-, 12T- and 13T-sprocket
Chamber Vol : 294 ccmStandard engine mounts (�32mm x 92mm)Chassis-specific engine mounts
Max RPM : 11000 rpmIgnition with start supportMetal clutch friction discs
Ignition : PVL Fire 65050W alternatorDell'Orto carburettor VHSH30W
Clutch : 2-disc dry centrifugal clutch
Drive : �in chain type 428
